Hey Steve,
Is the voltage reading at the battery? How many volts are you getting when you rev the engine to 3000RPM?.. You should get 13.8+ volts... take your battery to your local auto parts store - O'reilly's, autozone, or battery shop and have the CCA (Cold Cranking Amps) checked,, this is the true test of a battery.. if they are low.. get a new battery, then check the output.. if you are not getting the 13.8+.. have the alternator checked...
SOURCE: 2001 Buick LeSabre - Noticed
do this start your car. and disconnect the positive battery cable while the car is running. let me know if the the car dies.
SOURCE: speed sensor low voltage
lets do this ck voltage with voltmeter at battery post on the back of you alternator. you have to have at least 12.35 volt at least. most likely around 14.-16.. but 12.35 min. any lower replace.
hope2help
SOURCE: 96 corolla has no voltage at fuel pump, i have 12
Yes the fuel pump/relay is tied to the ECM,but its also tied to the park/nuetral safety switch also.
SOURCE: 1962 CHEVROLET TRUCK with points
If/How long will it crank over before it stops? Are you saying it will crank over, but very slow? Has it been sitting quite a while. Got good spark, and fuel?
