Question about Toshiba Computers & Internet
How do i bypass bios password on toshiba tecra A8
  • Toshiba Master
  • 5,040 Answers
Fred Ayieko wants more answers to this question
hijacked, today?
this PC is 12 years, old and as such uses BIOS PW methods used back then, (there are 3 ways on all PCs made)
1: pull NVRAM/RTC coin cell battery, (see below) or jumpers.
2: stored, in EEPROM (custom PW chip) very heard to reset,
3: stored in TPM modern PCs, and you are doomed lacking direct OEM intervention (by LAW)
so lets pretend your PC, (ever youtube this all day)
it is Generation 1, NVRAM and jumpers.
if it is GEN1 and I'm not saying it is. and there are 12 motherboards used on any A8 world wide and are NOT the same here is the GEN one methods. (and if fails proves its gen2.)
acid test: 101.
GEN1 (the maybe jumpers but IDK)
1:remove the HUGE battery first, leave it out until PC runs right again, 12years old batteries short, and are CHAOS.
2: AC pack unplugged.
3: dismantle the PC as needed to reach RTC/NVRAM battery.
as seen below. this one is Yellow, can be blue or?
we have no manuals at Toshiba (30 manuals there)
that show any jumpers at all.
4: remove the battery some solder down others just unplug
this A8 from Europe just unplugges.
5: once you are 100% sure this battery (niiMh) and is recharable is pulled, for SURE.
6: short the 2 battery pins on the PCB side, never short a battery ever ok,. just the motherboard side, we short using a jumper wire those 2 abandoned pins,
7: NVRAM is now 100% ERASED ! in 1 nano second .
the PC now how has zero power, and NVRAM is now empty.
What it really does is have random data, if you learn how NVram works.
8: put back the PC, no jumper connected. as above.
9: leave out the HUGE now bad old battery, leave it the h3ll out until such time the PC runs perfectly again on AC. do that now.
10: power on the PC, if PW still set then your PASSword for sure in not stored on NVRAM is it.? no.!
11: weeeeee, I can now get to BIOS F1 page. three cheers.
12:
do the inside BIOS pages set to defaults now.
power on hammer F1, and BIOS now is up on the screen.
do the BIOS time and date now, SAVE and EXIT BOIS and reboot or power cycle the PC.
there is how to do it or learn if your PW is in side that NVRAM.
if the PC was parked for months on end you need to recharge it per the manual, OK or the PC can not be used. the RTC NVRAM battery must be charged first.
the battery charge only happens turned on, (oddly) as the manual clearly states in Chapter 6 page 5 below.
so do details HELP?
how do i bypass bios password on toshiba tecra A8 - a8a-p4jtowbtouygind4aa4y4bam-3-0.jpg
the manual is here,
https://support.toshiba.com/support/modelHome?freeText=1200013233&osId=50
Posted on Nov 23, 2018
  • 1 more comment
  • Anonymous Nov 23, 2018
    a tech to tech answer would be.
    remove all power in and outside to the PC.
    there at 3 power sources some are 4 but this PC is 3.
    the way all day for caps to discharge, inside PC. 1hr may do it> who knows,
    no man on earth knows the cap discharge rate.
    so a SAVVY tech knows to short the old battery pins. RTC battery out. for sURE.
    this resets it in 1 nanosecond.
    this causes the NVram to forget every thing IT EVER KNEW
  • Larry Ng
    Larry Ng Nov 23, 2018
    the tree on the left is TPM (win8 up)
    or the MAGICAL EEPROM PW chip , horror.
    the PW on all PC if this era was located in 1 of 2 places.
    NVRAM or EEPROM , and the latter does not reset easy nor are the jumper for EEROM>
    only risky hacks work on EEPROM based GEN2 PCs
  • Toshiba Master
  • 3,577 Answers
Hey Edmore,
Sometimes you can remove the battery for a few minutes..Did you supply the password??... shut down the computer... remove the battery, wait for several minutes... reinstall, then restart..see if this works...
Posted on Jul 31, 2017
    detail matter, !
    there are 12 steps, not just 1. sorry.
    if you don't now how NVram works why post?
SOURCE:
SOURCE: Cant get the password of Tecra A8
Clear it with the 'clear cmos jumper'.
Posted on Jul 29, 2008
SOURCE: Bios Password
From what I remember a bios password is easy to remove in some Toshiba laptop models. You just remove the battery. Pull the RAM out (make sure you are grounded when doing this--at a minimum don't walk around or shuffle your feet while touching the RAM) Under the RAM there should be a piece of mylar tape. (shiny brown or black) That should expose 2 or 3 solder welds where no component is located. Take a paperclip and make contact with the welds for at least 10 seconds. This should short out where the bios is stored.
For the HDD issue this might work:
Try F8 before the system POST(s) to get to ADMIN account in safe mode. Then go to control panel and user accounts and remove the password. This only works depending upon your OS. Good luck.
Posted on Feb 14, 2009
Geekman
  • 32281 Answers
SOURCE: download network drivers for toshiba tecra 8 laptop
Download the appropriate XP or Vista network driver for your model laptop from the Toshiba WEB site from their download page.
For a shortcut to the Toshiba's download page.
Copy and paste this address into your browser's URL address location.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1209157&rpn=PSAA0U&modelFilter=A100-S8111TD&selCategory=3&selFamily=1073768663&selModel=1209157|PSAA0U
Posted on Feb 21, 2009
kaybicks
  • 85 Answers
SOURCE: forgotten bios password on toshiba tecra a10. How
Hi
Just reset it, to do it just open the memory compartment and look for the bios battery number 2025 or 2016 and take it out the battery for 1 minute just to be sure it will reset. Just feel free to ask. Hope it may helps.
Regards,
kaybicks
Posted on Feb 26, 2010
SOURCE: toshiba tecra a8 "ALERT: System
  1. HELP ME toshiba laptop satellite A120 system protection failure password =,
PASSWORD I DON'T NO (SUBROTO.BOSU@GMAIL.COM)
Posted on Nov 03, 2010
Toshiba tecra a8 alert system protection failure password toshiba tecra a120 alert system protection failure
Toshiba tecra a8 what pass word.?
BIOS
or windows, if using windows, unstated. (windows login screen?)
if not login screen for windows seen that means its a BIOS PASSword. not good that.
first ones run XP, do you still run this? old virus magnet OS?
why not ask TOSHIBA this, they made it, not us.
https://support.toshiba.com/support/modelHome?freeText=1364536
Jun 11, 2018 | Toshiba Computers & Internet
WHO MAKES BIOS FOR TECRA?
ACPI Flash BIOS version 3.20 for Tecra A8 (PTA82) Posted Date: 2016-09-19 ' Version: 3.20 ' Size: 3.82M ACPI Flash BIOS version 3.30 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 3.30 ' Size: 3.82M ACPI Flash BIOS version 1.40 for Tecra A8 (PTA82U) Posted Date: 2016-08-24 ' Version: 1.40 ' Size: 3.54M ACPI Flash BIOS version 1.60 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.60 ' Size: 3.52M ACPI Flash BIOS version 1.50 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.50 ' Size: 3.54M ACPI Flash BIOS version 1.30 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.30 ' Size: 3.54M
Apr 02, 2014 | Toshiba Tecra A8-EZ8311 Notebook
Enter bios toshiba tecra a8
when powering the computer up hold the F8 or esc key
Jan 28, 2014 | Toshiba Tecra A8-EZ8312 PC Notebook
I have a toshiba tecra a8 pta83e when i switch my laptop on a black screen comes like DOS and written on (alert: system protection failure! password= ) so can u help me and...
JAN 2018 post. answer above forgets the owner has no PW.
wow. that said that clearly to me above;
that PC has rechargeable battery deep inside. (oddly)
the above poster only fixes Change PW never LOST PW.
ok?
Lost PW or dead battery fixes.
this pc , turn it on, and let it charge the RTC battery deep inside,
Thoshiba is the only PC that does this Ni-Mh battery deal.
and only charges turned on.
after charging this battery below
turn PC off then on the see if the PC asks for BIOS admin Password, if yes post back or read my 2 other A8 posts here
with the 12 steps to clear this PW. ok,
if the NVRAM scrambles (as all do A8 if parked in shelf for say a year) then the NVRAM scrambles and now the PW is lost.
so it ask for PW, if you
power on and hammer the F1 key, BIOS may POP to 1st screen
then hit BIOS reset key for, return to default settings.
then exist and save.
proof
the USA A8 manual quote, read that carefully !
rtc2-p4jtowbtouygind4aa4y4bam-3-0_0.jpg that last line above, is OMG , really? and is true.... must be left on for say 24hours, 1hr min, I guess.
also the battery this old will be bad, In most cases,
sorry never seen a 12 year old Ni-Mh any good anywhere.
Jan 26, 2018 | Toshiba Tecra A8-EZ8311 Notebook
BIOS PASSWORD
This is a Toshiba bug.
Find an authorised repair center here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/gaspLocator.jsp?subs=tais
They'll fix it for free. Should take them only a few seconds so try to convince them to repair it while you wait to save yourself time.
Feb 22, 2009 | Toshiba Tecra A8-EZ8313 Notebook
How Can I Remove Bios Password on Toshiba Tecra A8-EZ8313
Enter bios. Go to user setup. Type the password.And that`s it
Jan 27, 2009 | Toshiba Tecra A8-EZ8313 Notebook
Toshiba Tecra A8 EZ8512 Bios problem
Good day to you.
I have a toshiba Laptop with Bios Password problem. I cannot start my system anymore, cos the laptop is requesting for Bios password which I dont know or have.
Oct 25, 2008 | Toshiba Tecra A8-EZ8311 Notebook
Open Questions:
Computers & Internet Logo
317 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
