Question about Samsung LN46A650 46 in. LCD HDTV
My samsung hdtv got wet and now will power up peep three times then turn off
  • 585 Answers
Dry it inside with a hair dryer before using it. hopefully it will dry out
Posted on Aug 01, 2009
Samsung DLP not turning on
usually the colorwheel will prevent the set from powering up when all three lights blink. Diagnosis assistance is available for free from www.tvrepairworld.com
Jun 15, 2012 | Samsung HL-S5086W 50" HDTV
Samsung HLN617w won't turn on
How old is the surge protector you used? Because they only last for so long and can absorb so many surges. I hate to say it but it sounds like your TV sustained a power surge.
Nov 07, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. ...
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. It always does the same thing: comes on for 1 minute, then powers down - there is no wait time in between unplugging and powering on. All fans seem to work and I cleaned the dust out of it. Help.
Nov 04, 2010 | Samsung HLN507 50" Rear Projection...
My samsung 46 in. hdtv will not power up when plugged in standby light is lit turn on then it flashes lamp led it after theen goes back to standby mode repeats this process three times then all three...
Have you Check the Lamp Fan is it still running while Lamp trys to light?Ballast board is what powers Lamp on ,but if the Lamp Fan is defective Lamp will not light.
Sep 10, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Hi there, my Samsung WB500 camera can not get it's lens closed. It stands open all the time and is doing nothing. When I turn the power on, it 3 times makes a hard noise 'peep peep peep', no display and...
This is a common problem with cameras. They can get bumped when the lens is out, and that can jam the gear assembly, or break a gear. I could run down all the things you can try to free it up, but there is a better web page that deals with issues like this. The page deals with error messages for the lens, but the beeping you hear is an error message, also. Follow their suggestions to try to free the lens up- maybe you'll get lucky. They say that, in about 50% of the cases, it can be fixed by trying their suggestions. Here's the site:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If nothing works, make sure you get an estimate before getting the camera repaired. Sometimes the cost of repair justifies going ahead and purchasing a new camera, on sale, and is often less expensive than having it repaired. Good luck! Hope you get it working again!
May 18, 2010 | Cameras
I have a Samsung LNS3251D 32-Inch LCD HDTV , that after two years of use is going Off/On every ten seconds after the initial turn On. I understand from reading this forum that the Samsung 40 inch LCD has a...
In almost all cases where the set is taking a long time to turn on and then turning off it will be the Power Supply board that will have bulging capacitors, usually three to five. Look on the upper right side of the Power Supply and look for any blown caps. You can replace these caps and you will be fine. Now the other cause can be the Power Switch is shorting out. You can disconnect the the Power Switch but not the IR sensor and then turn ON the set with your TV remote and see if this stops the problem. If you are not skilled in component level repair on the Power Supply board then buy a new Power Supply board and install it.
Apr 15, 2010 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung HC
Replace the Power deflection board that should solve your problem. You can get a replacement board for your model at the following link.
http://servicemanuals.vstore.ca/product_info.php/pName/p59a-pwr-def-board/cName/samsung-parts
Apr 27, 2009 | Samsung HC-P4752W 47" Rear Projection...
NV30 froze
Samsung NV30 turns on then beeps then turns off
Oct 29, 2008 | Samsung NV30 Digital Camera
My DLP TV wont turn on.
As part of the power up sequence on the Samsung HLP-4336W the lamp isn't turned until timing pulses are detected from the color wheel. The color wheel motor is powered through the flat brown four conductor ribbon cable and the timing pulses are detected over the the three conductor ribbon table.
Jun 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung LN46A650 46 in. LCD HDTV Logo
349 people viewed this question
Henry  Thomas
Henry Thomas
