Question about Intel Motherboard
No image The computer im working on does not display any images. no beep no nothing the video card was tested in a other computer and work fine. is the agp connector can jump like this ?
    Problem Solver:
  • 6 Answers
Does it beep if you try to turn the computer on without the graphics card inserted? If it does chances are only the AGP port died and you might still be able to boot the machine with an old PCI graphics card.
Posted on Jul 27, 2009
Samsung syncmaster 2220 blinking blue light and no image display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
Canon SD850 IS showing "unidentified image" after pic is taken
There’s nothing inherently wrong with your notebook, and nothing you can readily repair; most notebooks’ video cards and their drivers aren’t equipped to display video through a projector and on your notebook at the same time. You could try updating your video drivers, but you will likely have to change your system’s primary video source to the projector. Solution:
Different PCs may require slightly different steps, but opening Display Properties in Windows XP should generally be your starting point. Click Start and Control Panel and double-click Display. In the Display Properties dialog box, click the Settings tab. At this point, you should consult your notebook’s users manual to configure your notebook to use the projector as your primary video source.
Mar 06, 2008 | Canon PowerShot SD850 IS Digital Camera
Computer powers on with no image. It is an Acer M410. If memory is removed it beeps.
this issue might something to with the memory or the video card. When computer beeps when you restart it, it means to say that the motherboard is working fine. Try to check different memory (RAM) or check also your video card. If your motherboard has an onboard video you can also use that one temporarily to check if the video card is faulty.
May 30, 2011 | Computers & Internet
My Toshiba X200 doesn't show any image.I've bought a new motherboard, but still no image appears.The tech that told that the problem was with the motherboard (that was supposed to be burned).Now he tells...
enable what? BIPS? never heard of it in the last 10 years, are you sure you are dealing with a PC tech there?!
Have you tested that the RAM on the computer IS OK?
Have you tested that the Video card on the machine is OK?
has any real troubleshooting been done on the machine?
if he just told you the motherboard was burned without doing any other testing you are dealing with a fraud.
Nov 07, 2010 | Computers & Internet
Dell Dimension 9200 beeps on startup, with nothing...
A beep code of 3-3-4= Video Memory(RAM) Test Failure that would explain why you get nothing on your screen the first thing you would need to do is disconnect your monitor and try it on another computer. if it works fine then the problem is your video card. If that the case and the video card is intergrated with the motherboard, you will need to repalce the motherboard --- Sorry-- Please vote me a 10 when this works
May 20, 2010 | Dell Dimension 9200 PC Desktop
It displays colorful lines on the monitor...cant see nothing
Test your laptop with an external monitor and find out if the external video goes bad too. If both, internal and external images go bad, you have a problem with the video card.
If external works fine and only internal goes bad, most likely it’s either bad video cable or LCD screen failure.
May 21, 2010 | Nvidia GeForce 7200 Graphic Card
Image not being displayed through projector
make sure the resolution matches. the projector uses 640x480.
May 27, 2009 | SharpVision XV-S96U Multimedia Projector
No screen image
You gonna need an spare monitor, video card and a memory card. But first have the RAM card and the video card(if plug in) be clean or reseat. Use clean soft eraser to clean its edge connector, both side. And check your video card for dirt or stock fan if it have. Do this cleaning when unit is off and unplugged to wall socket even UPS. Also reseat the monitor cable. Then try to power it up again.
Next step;
And since it beeps it seems one component is failing or loosing its contact with the board. Then use the spare ram, then the spare card, if still not viewing any try to swap the monitor.
Or if you have no spare if cleaning only doesn't help, its practical to bring it to the expert.
May 25, 2009 | ASUS P4S800-MX Motherboard
I have a ViewSonic Monitor, model number Vs11307. The screen is all blurred and the screen isn't adjusting properly. The screen is shifted to the right and I have a blank rectangle at the left side. I...
I had the same problem same model. The image was off center to the right and it couldn't be fixed by the auto-image adjust or the manual adjust.
My solution was really simple, I moved a video player (RealPlayer) onto the monitor and maximized the screen, then pressed auto-adjust once. It worked.
Jul 14, 2008 | ViewSonic Computers & Internet
E-GeForece 6200 displays partial image when plays avi video
hi im wesley. um a problem might be that the players you are using dont have the right plug ins or dont support the file try using vlc player it works with almost everything
Jul 07, 2008 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Intel Motherboard Logo
127 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
