Question about Acer Aspire 9300 Notebook
Laptop wont turn on.. at all.... Aspire 9300
I press the power button and this stays illuminated but nothing else happens. It is plugged into the power and the fans turn on for a few seconds then go off. There is no life from the screen or any noise from the machine. I have tried pressing everything just to get to DOS but can't get any life out of it at all. Help..!
  • tattyed2497 Jul 27, 2009
    Hi, thanks, as I said though the power light stays on, it doesnt turn off. The laptop just does not power up, it stays turned on but with no reponse. The fan starts for a second or 2 then stops. I have tried taken the battery on and turning it on via the AC adapter but it still doesnt boot up. cheers
Hey whats good I had the exact same problem with my computer. Im not a computer wiz or anything so I asked for help to and these a-holes told me i had to pay 200 just to talk to someone for 30 minutes!!! Fu** em!!! All I did was change out the power cord. It seems crazy as hell but it worked for me and Im up and running I hope this helps you out. Any questions contact me at noxx3577@gmail.com
Posted on Aug 05, 2009
  • 479 Answers
Please try following DIY
1.check with the refixing the battery,.
2.As you mentioned that the power comes for a while and then goes off so once check on adaptor mode without battery.
3.If these don't work this issue is related to motherboard need to checked by an h/w expert.
Thanks
Posted on Jul 27, 2009
I tried to power on my computer and there was nothing. It was plugged in and the battery light was blinking amber when I tried to press the power button. The light on the power cord is green but there is...
It sounds like the Power adapter is:
1. Not plugged into the computer
2. Not functioning
3. Has a broken connector (or the laptop has a broken power connector)
Unplug the adapter, remove the battery, hold the power button on the laptop for 30 seconds. Plug in the power adapter connector to the laptop - if the power indicator illuminates, remove the power cord, insert the battery ant then plug in the power cord. Press the power button (hopefully you're back in business).
If that does not help, p borrow an adapter from a friend and try it with your laptop, if it works, then go buy a new adapter!
Sep 05, 2011 | Acer Aspire 7740G6364 (lxplx02165) PC...
Hi. My acer aspire 5735 doesnt turn on. I turned the laptop off as normal however when i came to go back on it just wouldnt turn on. The charge light stays on to show whether the battery is being charged....
When a computer does not boot up, but the battery is charging, it could be a CPU or RAM problem.
Re-seat the RAM modules, this will make sure it makes proper connection to the motherboard.
Next try removing the battery and power up the laptop with just the power adapter connected. If it boots up then insert the battery while it is powered up.
Oct 23, 2010 | Acer Aspire 5735 Notebook
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Dec 08, 2009 | Acer Aspire 5315 Notebook
Acer aspire 9300 notebook black screen while in use
If there is power beside you,why not connect you laptop to the family power,it will be good to your acer aspire 9300 battery life .Pay attention to your acer aspire 9300 laptop have been 2 years old,i think it most properly some problem to your acer aspire 9300 battery.
Sep 24, 2009 | Acer Aspire 9300 Notebook
My Acer Aspire 9300 laptop wont turn on......light indicators are on (motherboard light blinks once, light bulb and battery lights on) but no power to fans so no start up. have had this happen before but...
Very possible that something has short circuited on the motherboard. I would also try re-seating the memory located on the bottom of the laptop(which could be loose explaining the intermittent nature of the issue). On an IBM I once fixed that had the same issue I took out the CMOS battery and battery for one week and then re-installed and that fixed the issue. But good luck to you!
Sep 23, 2009 | Acer Aspire 5315 Notebook
Had my laptop plugged in overnight. I turned it on
try to press the power button for more than 10 seconds and try to power it again
Jun 08, 2009 | Acer Aspire One PC Notebook
My acer aspire 9300 doesn't turn on.
Try this
Remove all power from the computer
Laoptop: remove the battary & the power plug
Desk top: remove the power plug
Hold the power button for 60 seconds
Plug your PC on and reboot
Feb 18, 2009 | Acer Aspire 9300 Notebook
Acer Aspire 7004 wmsi Will not start.
When you press the power button does anything happen? such as lights or LED's illuminate?
You could try the following -
1. Make sure there is nothing plugged into the computer (USB devices or memory cards etc etc).
2. Remove the power cable & the battery
3. Press the power button for 30 seconds
4. Insert the charger but not the battery and try and start it up.
If that doesnt work check the USB ports for damage and the port where the charger is plugged in aswell.
If they are damaged or it still wont start it will probably need repairing.
Jan 18, 2009 | Aspire (ATX-AS500W-BL) (atxas500wbl)...
Wont stay on
I suggest removing the battery when plugging it to the wall outlet or are you trying to charge it? I think the one that is spinning is the hard drive reseat it then lets see what happens try to purchase a new hard drive if problem persists. please indicate also the status of the lights on your laptop ill reply with more steps when you've indicated everything
Mar 22, 2007 | Dell Inspiron 1100 Notebook
Acer Aspire 9300 Notebook Logo
472 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
