That treadmill is about 20 years old and is not worth repairing and definitely not worth buying in the first place. Check all the wiring connections at the console and in the uprights. If it's not that then junk it.
It is second hand and if you didn't try before you buy then it not running is probably why it was sold
take it to an appliance repair shop and have it checked out
SOURCE: proforma 575 runs when no one on it but stops after a few seconds
These are two distinct problems. For the running but stopping it seems like a load or a feedback issue. I would start with the easiest - Lubricate,lubricate,lubricate the walking belt, you maybe overworking the motor drawing to much power causing shutting down - usually this blows the MCB (spendy)
The other users problem more than likely comes from the motor, sounds like a bad leg (check the brushes and armatures)
SOURCE: I have a Trotter 535 treadmill. I need to turn
visit wefixfitnessequipment.com and I will tell you how to flip the deck, tighten the belt and where to get lube. If you are planning on flipping the deck make sure you lube it with the right kind of lube!
B. Clark
Trotter/Cybex certified technician
15 years exp.
Dear Sir:
This is probably a 1(faulty speed sensor or the 2( speed sensor is not plugged in properly. Its also possibly a 3(faulty motor control board or lower board+ 4( Main motor faulty. Adjust the speed sensor see the diagram.
Run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for HELP
sincerley. God bless you.
ernesto cuadra
managua, nicaragua.
SOURCE: trotter 535 treadmill auto start and stop
1) Lube the Deck belt, very well according with your instruction manual maintenance.
2) Lube the rollers bearing too
3) Measure the input voltage motor, if there are The motor need repair.
4) Measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. God bless you
SOURCE: Download Trotter CXT Treadmill manual - where?
go please to www.fitness.manualsonline.com or www.iconservice.com
God bless you
