Question about RCA HD52W59 HDTV Projection Television
How do i start auto convergence - RCA HD52W59 HDTV Projection Television
    Genius:
  • 1,043 Answers
Press your MENU button on the remote. Move to SETUP and press OK. Then choose Convergence. You should wait until your TV has been on for at least 1 hour before you run the auto convergence. Once the auto convergence has run, you can do your own fine tuning. There will be separate adjustments for Red convergence and Blue convergence. You will use the arrow keys to line up two sets of lines. The instructions will show up on the screen. Good luck, and I hope this takes care of your issue.
Posted on Jul 27, 2009
Is there a way to manually adjust the convergence on a Hitachi HDTV modol #43FDX15B?
Hi James,
If Auto Focus (Auto Convergence) won't complete the set-up stop trying to adjust it. There is a fault in the convergence circuit!! ICs have to be replaced and maybe some burnt resistors.
If you access the service set-up menu and try to adjust the "defective" circuit the Auto-focus may not work correctly after the IC's, etc are replaced. Experienced technicians know that the service menu allow easy resetting to correct the misalignment, etc. "First Time" technician can be easily misled, waste a lot of effort and never get a correct picture.
If you want to attempt the repair, buy the correct parts from a service guy that does this type of work. I suggest having the repair done by a local competent technician that is experienced with Hitachi Convergence Problems. It is considerably more challenging than changing a fuse.
Our Convergence Gallery shows a variety of Convergence Faults. If you live in Toronto, ON., Calgary, AB., or Vancouver BC. it costs $257 for Hitachi in home convergence repair.
Good luck.
Robert
Nov 17, 2015 | Hitachi Televison & Video
Auto covergence will not converge
Try this with tv turned off press and hold at same time the vol- and ch- wait untill TV comes on then release Buttons,TV will either start auto convergence or you will be in the service menu to adjust convergence.
Jun 26, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Auto Convergence Problem, no menu option, 3d looking picture
yes the board components are out.not to replace whole board only two convergence ic on the board needs replacement. they are not at all costly this link which is mentioned belkow has all the instructions to replace the ic on the board just click it and follow the instructions  http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Mar 07, 2009 | RCA R52WH73 Projection Television
Convergence problem
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
You can download the manual here. Insrtuctions for auomatic convergence are described. I copied the instructions below.
Automatic Convergence
Your HD Monitor’s picture tubes might have been disturbed during delivery or
after you moved the HD Monitor, causing the color in your HD Monitor to be
out of alignment. The colors adjust by starting auto convergence.
IMPORTANT: Auto convergence works best once the HD Monitor has
warmed up for at least an hour. If you've just unpacked your HD Monitor,
it's a good idea to repeat the Auto convergence function when the
HD Monitor's been running for at least an hour. See page 38 for more
information about Auto convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu
appears. The cross in the middle of the screen should be yellow. If it is not,
use the arrow buttons to move the red cross to overlap the green cross.
Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle
of the screen. If it is not, use the arrow
Sep 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Convergence prob for d52w26 rear projection tv 52"
If the auto-convergence is not working then the convergence amp ICs are starting to fail. If you can solder, try resoldering the pins on these ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Dan
Jul 14, 2008 | RCA P52926 52" Rear Projection Television
Auto convergence not working 142cm LG rptv
If the colors will not line up in one corner of a standard projection set, it usually means that one of the convergence output IC's has burned out and needs to be replaced. This is very common. If you do not have experience replacing parts and soldering PC boards, then the defective IC should be replaced and the convergence circuits realigned by a qualified tech familiar with convergence circuits in projection sets.
Aug 26, 2007 | Televison & Video
RCA HD52W59 HDTV Projection Television Logo
297 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
