Probably you have a problem in the power supply board .
Vizio lcd or led always has a problem in the standby circuit of the power supply .
SOURCE: I need to change the resolution to 1080 on a vizio D650i-B2
The resolution for TV's is auto sensed by the content being sent to it.
If you are playing a 720p file, you cannot make it 1080p. 720p vs 1080p Can You Tell The Difference Between HDTV Resolutions
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
That's what I've been told. Just wanted to hear a couple more opinions. I appreciate it!!!
Is there any way to tell if it's the power supply or he main board, or should I just replace both? Thanks again
