There are a couple of possible answers, depending on whether you're talking about liquid ounces, or weight ounces.
For liquids, there are 8 fluid ounces in a kitchen '1 Cup' measuring cup. That means 48 fluid ounces are the same as 6 cups, 3 pints (2 cups per pint) , or 1-1/2 quarts (two pints per quart).
For weight, there are 16 ounces in a pound. (One fluid ounce of water also weighs one weight ounce, which is the basis of the adage 'A pint's a pound, the world around', since a pint is 16 fluid ounces, and 16 fluid ounces of water, or near-water like some beer, will then weigh a pound' ).. Anyhow, in this case, 16 goes 3 times into 48 ounces, so it will weigh 3 pounds.
For metric, 2.2 pounds per kilogram, or 29.5735 milliliters per fluid ounce.
A.PREPARE Step 1. Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug ( do not use a paer cup). Step 2. Empty the water in the water Reservoir. B.FILL AND CLEAN Step 1. Pour the vinegar into the water reservoir and fill it to the top edge of clear viewing area. Step 2. Place a ceramic cup in the Drip Tray and run a brew cycle. DO NOT USE A K-KUP … just press the Large Cup Button. Pour the contents of the cup into sink. Step 3. Repeat the brew process until the Water Reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle. Step 4. Now fill reservoir with fresh water and let the brewer stand for 4 hours while still on. C.RINCE Step 1. Ensure the Water reservoir is filled with fresh water. Step 2. Place a ceramic cup on the drip Tray and run a regular brew cycle. Pour the contents of the cup into the sink. Step 3. Repeat the brew process until the Water Reservoir is empty. Step 4. You may need to perform additional brew cycles if you notice any residual taste.
I realize you think it does not need descaling to to it 'not being used much.'
However you may have hard water and I would think descaling is definitely worth a try. There might be scale built up on the water level probes in you machine.
Your b60 may need to be descaled. There might be scale built up on the water level probes in you machine. I have listed the directions below:
Brewer De-Scaling Instructions Brewer Model: Elite B40 ' Classic B44 Special Edition B60 ' Platinum B70 To begin, you will need the following: • 48 ounces of undiluted white vinegar • Large ceramic mug (do not use a paper cup) • Access to an empty sink PREPARE Step 1: Empty the water in the Water Reservoir. Step 2: Disable "Auto Off features." FILL AND CLEAN Step 1: Pour approximately 48 ounces of the vinegar into the Water Reservoir. Step 2: Place a large mug on the Drip Tray Plate and run a brew cycle.
DO NOT USE A K-CUP , just press the BREW Button. Pour the contents of
the large mug into the sink. Step 3: Repeat the brew process without a K-Cup until"ADD WATER"
is indicated. Step 4: Now let the Brewer stand for at least 4 hours while still on.
Step 5: Discard any residual vinegar and rinse the Water Reservoir thoroughly. RINSE Step 1: Ensure the Water Reservoir is filled with fresh water.
Step 2: Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink. Step 3: Repeat brew process until "ADD WATER is indicated.
Step 4: You may need to perform additional water brew cycles if you notice any residual taste. NOTE: If "DE-SCALE" is still displayed after completing the procedure, repeat the descaling procedure above.
PREPARE
Step 2: Disable "Auto Off" features.
FILL AND CLEAN
Step 2: Place a large mug on the Drip Tray Plate and run a brew cycle. DO NOT USE A K-CUP, just press the BREW Button. Pour the contents of the large mug into the sink.
Step 3: Repeat the brew process without a K-Cup until "ADD WATER" is indicated.
RINSE
Step 3: Repeat brew process until "ADD WATER" is indicated.
NOTE: If "DE-SCALE" is still displayed after completing the procedure, repeat the de-scaling procedure above.
you can contact Keurig at 1-866-901-2739 or Keurig.com You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours. Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water. If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
