Dmm WMK-A06 Pearl Steam Shower Unit, build-in Shower Panel
Problem for Dmm WMK-A06 Pearl Steam Shower Unit, build-in Shower Panel
Ariel 701 wiring
By hunter_man_1 on Jul 27, 2009
I have the same problem, the electrical details don't make sense to any of the electricians I've talked to about this. I just need to know what breakers and wire gauge I should use, then I can connect it up myself. Has anyone found a solution??
Best Solution
posted on Aug 06, 2009
Very Helpful)
DSmoker
Rank: Apprentice
Rating: 100%, 3 votes
I have the same tub and had a similar issue. We originally connected a 12guage with 20 amp circuit breaker and breaker kept trippin. The solution was to connect 10guage wire with a 30 amp breaker. Connect that to a gfi then connect the 12 guage wire coming out of the generator to the gfi (woulda made sense to just have 10g coming out but it was made in China). Being that theres only a short lead coming out of the generator its fine to run 10gauge, just make sure there connected seperately to a gfci breaker. The pump is fine 12 guage 20 amp.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Aug 01, 2009
Somewhat Helpful)
joed202902
Rank: Guru
Rating: 88%, 179 votes
See if the unit has any information about the power consumption. If it's given in watts, then watts/voltage = amps.
If given in amps, then it's probably either 15 or 20 amp, and either 120 or 240 single phase.
Minimum wire size for a residential appliance is #14 awg, but you can use #12 awg. It's always safer to use the larger size wire.
Was this helpful?
Yes
No
Popular Solutions for Dmm WMK-A06 Pearl Steam Shower
Questions and Unsolved Problems for Dmm WMK-A06 Pearl Steam Shower
Do you recommend Dmm WMK-A06 Pearl Steam Shower Unit, build-in Shower Panel?
Answer
Answer
i have a triton power shower, when i switch it off, water still comes out ,what is the problem
Answer
the setup has a red circular plastic ring that is threaded on the handle stem. It seems locked into... (More)
Answer
cannot ajust tempreture control after fitting new pump
Answer
i have just installed a quarter turn Quattre Mixer Shower from B&Q and cannot get the water... (More)
Answer
I need to replace the cartridge on my 1990's vintage shower/tub set but I can't find a model number... (More)
Describe your Shower Hardware problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Shower Hardware Experts
Top Plumbers
in Sedona, AZ
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(866) 897-9936
316 2837038
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
