Question about GE Spacemaker JVM1640SJ Microwave Oven
Over The Range Microwave new models too tall need under 15 in hig
Old over the range microwave was 30 inches wide, 15 inches deep and 14.5 inches tall (height) Can't find any microwave that is under 15 inches in height. Anything over that will not fit. Any suggestions?
  • Anonymous Mar 19, 2014
    84 inches tall,8 feet long, 5 feet wide
  • Anonymous Mar 25, 2014
    I need to replace an microwave so I don't have to get into the expense of tile work and new cabinetry. Current measurements are 30 inches, 14 inches deep and because the bottom is angles back it goes from 14 to 16 inches
    Problem Solver:
  • 18 Answers
Cut the cabinet off. a cabinet maker can do it and you can tell if they ar good
Posted on Jul 28, 2009
  • kitchdesign Jul 07, 2011
    That only works if you cabinets are 1/2 inch over lay. Full overlay has no room to cut.
I'm trying to convert a over the range frigidaire microwave that is 30" by 15.5" by 15" into cubic feet.
generally speaking you buy and OTR microwave by width, i.e., 30" wide is the standard width of all most all OTR . so any 30' wide microwave will fit. when talking about cubic feet, they usually are talking about the interior capacity of the microwave. but if you really want to know cubic feet of above dimensions, then multiply all three together and divide by 1728. (4.036 cuft)
Aug 29, 2015 | Frigidaire Microwave Ovens
Measurements to replace R 1460 over the range microwave
Almost all over the range micros are 30 inches wide. They did make a few 36 inch models but most are 30. Top to bottom back measurement can be between 16 to 18 inches. Most makes are similar in size. Back wall mounting plate will have to be exchanged since each company has a slightly different design but the wall plate comes with the new unit along with mounting hardware.
Apr 14, 2015 | Sharp Microwave Ovens
I want to replace an old microwave from 1988: GE Model# JVM130001. What microwave will fit in that space?
Laura, most any over the range microwave should fit that space. It may hang a little below your height but that should not be a problem.
Jul 29, 2014 | GE Microwave Ovens
I have an old GE Microwave jvm240av001 and would like to know the specs so I can replace it. It is so old (1995) I can not find anything on line. Please let me know if you can help. Thanks so much!
Hi and welcome to FixYa, I am Kelly
(trim kit required)
For all newer units the dimesnions are
15 & 3/4" high 16 & 1/2" high hole required for vent connection in rear
15" deep
Needs a 30 inch wide hole for installation
or call GE 1-800-626-2005
Use this link for all models OLD and NEW:
http://www.geappliances.com/service_and_support/literature
To get dimensions you look up installation manuals for each model.
Your manual cam up here: (1.51 Mb)
http://www.geappliances.com/search/older-pdfs/49-8621.PDF
Your microwave is not vented externally but your replacement microwave will be capable of being used in a non-external vent and an external vent cofiguration. Personally.... I would recommend the external vent installation. Either will work.
Thanks for choosing FixYa, Kelly
Sep 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Do you know the dimensions of the GE jvm230 over-the-range microwave oven?
Just measured mine as I'm looking to replace it.
30 inches Wide
15 inches high (front)
16.5 inches high (rear)
13.5 inches deep
Nov 18, 2010 | GE JE1540 Microwave Oven
What are the dimensions for a Whirlpool Microwave MH7100XYB? Whirlpool doesn't have the dimensions on their site and I'm trying to replace it.
30" wide x 16" tall x 14" deep. Tried to find a replacement for mine of that size with no luck. Turned out a $30 capacitor needed replacing ($90) service charge.
Sep 21, 2010 | Microwave Ovens
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
#mmv4203dw installation, the old one is out
The new microwave oven dimensions are 29 7/8" wide, with a depth of 15 1/2" and a height of 16 15/16". These measurements are listed on page 3 of your installation manual. If you do not have an installation manual, you can go to managemylife.com and type in the model number you provided under the "Manuals" link. The owner's and installation manuals are both listed in .pdf (Adobe) format that you can download or print for FREE.
So...to answer your initial question, "Yes", this model microwave oven will fit in the space that your old one previously occupied.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 27, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
Spacemaker microwave
What I did was get a shorter cabinet and put it in most suppliers have the same models unless handmade.
Jan 14, 2008 | Tappan TMT104E1 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
5,089 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
