Question about Motorola Mobility H700 Wireless Headset
My headset flashs blue but does not work with my BB Curve. It had worked, I lost it and just recently found it and charged it and was Able to pair it with the curve but it does not work.
  • Fergal Gallagher Jul 28, 2009
    The Bluetooth device is a Motorola H700C and I use it with a Blackberry Curve.
  • Fergal Gallagher Jul 29, 2009
    does not work .
    President:
  • 2,777 Answers
It's possible the headset has failed. Try pairing it with another phone / device, maybe even a friends. If it still doesn't work then you know the actual headset has failed. If it does work, and then still doesn't work on your blackberry let me know.
Tim
Posted on Jul 29, 2009
Hi there
Would you by any chance have a music or video file (with audio) on the Curve that you can play? If so, after pairing it, play the file and while it is playing, attempt to increase the the Curve's volume and also the headset's volume (if it has controls). Does it play?
If you don't have any file to play, try making a call and see if you can hear the person speak.
The blue flashing does indeed mean the headset has paired successfully.
Let me know if increasing the volume on both the Curve and the headset helps. I know its a very simple suggestion, but please get back to me so we can proceed further.
Thanks
nLinked
Posted on Jul 28, 2009
  • 13,433 Answers
Are you sure you paired it properly? Send me the brand and model and I'll see what needs to be done.
Posted on Jul 27, 2009
Won't pair with Motorola HS850 headset
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Im trying to pair my verizon cell phone to my motoral headset
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Motorola Mobility Bluetooth Hands Free...
Pairing CK 3100 first time with HTC touch
5) Select the Parrot device and click add
6) You will be required to enter in a pass code which is standard ‘0000’, but try '1234' again if that doesn't work
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 24, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Samsung Bluetooth WEP210 and Blackberry
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Searching for the headset on the Blackberry
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Dec 15, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Pairing WEP200 w/BB Curve (8330)
Just make sure when you're first syncing this to your cell phone, hold the main button for a REALLY long time. NOT till it flashes (keep on holding it). It will eventually go from flashing to a SOLID blue light, and that's when you sync. It'll probably take like 30-60 secs of holding.
That's what worked for me, my phone wouldn't recognize the headset until this.
Jul 02, 2008 | Samsung WEP200 Headset
H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
Nov 08, 2007 | Motorola Mobility H500 Wireless Headset
H700 Headset
Is the Samsung bluetooth turned on?
Jul 17, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
20 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
