Question about Daewoo KOR-630A Microwave Oven
I NEED TO KNOW HOW TO OPERATE MY DAEWOO KOR 115B MICROWAVE OVEN
I have no manual for this appliance and cant figure how to set thew time and power. It just seems to work on a de frost setting as things can get warmish bu-t not much more. I think I am trying the wrong settings. Help! Rod McGregor in the Karoo
Hi Rod. did you find a solution? please let me know.
LC Boonzaaier
lcboonzaaier@gmail.com
Posted on Feb 15, 2011
  • 4 Answers
Will find manual here
http://www.daewooelectronics.co.uk
Posted on Mar 03, 2010
MY DAEWOO MICROWAVE KOR 1B4 H JUST STOPPED WORKING.
Maybe time for a new one. But just in case check the power outlet still has power and the circuit breaker is not tripped.
Dec 01, 2015 | Daewoo KOR-1B4H Microwave Oven
Why would the microwave keep running if we just close the door and no time is set?
Good Afternoon Friend,
I understand that your Frigidaire microwave continues to run, when you close the door and no time is set. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. You might need to set your clock before doing anything else. Put a cup of water inside your appliance and try to heat it up. If you are still noticing your microwave continuing to run, even after no time is set, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Microwave Ovens
Unable to adjust power level, the power level button on the control panel does not respond.
Try pressing and adjusting the power level before setting the cook time, or maybe before pressing start. Worked on my Panasonic
Dec 12, 2013 | Microwave Ovens
Time and weight setting doesn't works
There will be a reset switch button on your microwave's timer or somewhere on the appliance. Try the button and if it doesnt work then call customer care. It seems like a minor problem and can be fixed quickly..
Jul 29, 2012 | Panasonic NN-C994S Convection/Microwave...
How do I change the time on my Daiwoo microwave?
  1. Touch the CLOCK pad. This will activate the 12-hour system. (To activate 24-hour system, tap once more)
  2. Enter the correct time of day by touching the time set panels.
  3. Touch CLOCK pad.
You will know that you're changing the time when your display stops blinking and and the colon starts blinking.
If you have any other questions regarding your Daewoo KOR-630A, I located an online manual for you.
Cheers!
http://dl.owneriq.net/6/64d0773e-ca06-4c23-97b1-e039cfc523aa.pdf
Mar 27, 2011 | Daewoo KOR-630A Microwave Oven
I have never used the power feature and now I need to and cant find manual. How does the power feature work. I need to operate the microwave on medium power for one minute.
1 Use the number buttons to set a cooking
time. You can set a time from one second to
99 minutes, 99 seconds. To set a time over
one minute, enter the seconds too. For
example, to set 20 minutes, enter 2, 0, 0, 0 .
2 If you want to set the power level to
something other than High, press the Power
Level button, then use the number buttons
to enter a power level.
Power Levels:
Level Cooking PL
1Warm10
2Low20
3 Defrost 30
4Medium Low40
5Medium50
6 Simmer 60
7 Medium High 70
8 Reheat 80
9 Saute 90
10 High Hi
Hope that helps.
Mar 01, 2011 | Emerson MW8107WA Microwave Oven
Not a problem. I just want to know where to find the wattage for the microwave oven. It is a KOR 1N0A
The Daewoo KOR-1N0A is rated at 1,000 Watts with a 1.1 cubic foot capacity. The manual and documentation are available from the Daewoo site: http://www.daewooelectronics.co.uk/daewoo-product.aspx?folderguid=0039D237-8626-41AE-9D67-8F347C0C3B26&listguid=D897DFDF-A16E-452A-BB1A-7544B98F24DD . The links for these are near the bottom ot the page. If the direct link doesn't work, start at http://www.daewooelectronics.co.uk/daewoo-products-details.aspx?folderguid=DD695DCA-E930-41AC-BD76-1F59753A64B1 and then search microwave and then the model.
I hope this helps.
Jan 31, 2011 | Daewoo KOR-1B4H Microwave Oven
We lost our electrical power, when it came back on, the electrical panel (clock).. began blinking. The clock re-set with no problem. But, now the microwave won't work. I simply get a message that says...
Sorry to read about your problem, I hope this helps you out.
Anytime the power comes back on, their is a serge of power and things get blown up.
in the future, when you know you have a power outage.. turn off your main breakers,, then after the power comes on, then turn your power, you will not get the serge.
now go to you oven breaker and reset both switches, and see if your door lock corrects.
If you still cant get the microwave working, i have to give you this warning, and only say you have a defective control board.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | KitchenAid Microwave Ovens
Daewoo KOR-630A Microwave Oven Logo
312 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
