Question about TruTech PLV16190 Television
Our TrueTech TV remote came with a preset factory code that allows us to override our code in case we forget it. Unfortunately, my billiant children have figured out the factory code and are now able to override all of my parental control settings. Is there any way to reset the factory code.
    Problem Solver:
  • 5 Answers
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Posted on Jul 27, 2009
I have a Truetech CR130TT8, it's worked great, but suddenly some channels are broadcasting in Spanish & some have no sound. This happened before with the spanish & I was able to fix i
Do a factory reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 17, 2015 | Televison & Video
Tip
Lock and Unlock most TV's
http://www.ecoustics.com/tl/17973/
Polaroid:
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
0000, 1078, 1111, 3808, 5050, 8202.
Mitsubishi LCD TV:
Bypassing the V-Chip Lock After you set the lock, you need your passcode to view
a V-Chip locked program, view the locked TV, cancel
the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked
TV without entering your passcode. When your
password is requested, press the number 9 and QV
buttons on the remote TV control at the same time.
This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process
deletes your old passcode and prompts you to enter a
new passcode.
AOC: 0,0,0,0
LG: 7,7,7,7
PHILIPS: 0,7,1,1
SONY: 4,3,5,7
VIZIO: 0000, 2489, 5351, 8202, 8205, 8206
Emerson/Sylvania/Funia: 0000
NOTES from Emerson/Sylvania/Funai:
1.Make sure to enter the exact same new password in the
"Confirm Password" space as one in the space. If they are
different, the space is cleared for reentering.
2. Your password will be erased and return to the default(0000) when a power failure occurs or this TV has been
unplugged for more than 10 seconds. If you forget the password,
unplug the power cord for more than 10 seconds to
restore the password to 0000.
Sharp TV:
Sharp LCD TV Clearing the secret number using the remote buttons and the TV's buttons.
If you forgot the secret number, clear the secret number using the following procedure:
1) Press MENU, and the MENU screen displays.
2) Press Left/Right arrow buttons to select 'SETUP'
3) Press UP/DOWN arrow buttons to select 'EZ setup', 'CH setup', 'Parental CTRL' or RESET, and the SECRETNUMBER INPUTSCREEN DISPLAYS.
Press and Hold both CH UP and VOL+ ON THE TV SIMULTANEOUSLY until the message appears on the screen. The SCECRET NUMBER IS ****.
on Aug 17, 2010 | Televison & Video
Tip
Polaroid LCD TV Parental lock/unlock
Program Lock
Input the default password of 1235, the submenu
of Parent will display if the password is correct.
(a) When changing the password, the changed
password will be updated after four digits are input.
The word "ok" appears after you input the same
number twice, if the two passwords are different the
word "Failure" will appear.
(b) When All Clear is selected, all programs are unlocked.
(c) After you exit from the Program Lock menu and switch to a locked channel, the picture and
sound will be locked unless you input the correct password. The channel will remain unlocked
until the TV is turned off. After the TV is turned on again, the password must be re-entered to
view the locked channels again.
(d) If your program is locked, input the correct password to enter the Auto Search submenu.
Operating Auto Search will cancel the locked status.
(e) The default password is always effective.
(f) Entering the default password allows you to go to the Program Lock menu, then change the
password while the default password is still effective. This branch menu cannot be entered if a
wrong password is keyed in, In this case, press MENU to return to the previous menu.
(g) There will be slight delays while using the Lock All and Clear All functions.
● Child Lock
In Child Lock On mode, the buttons on the TV do not work. A prompt "Panel buttons are being
locked" will be displayed. However, the remote control buttons will still function. When the TV is
on and the Child Lock is on, a prompt "Locked, power off after 6s" will appear. Use the remote
control to control the TV. Otherwise, the TV will automatically enter into Standby mode.
I have a 32" tv... I must have press a button... bcuz now my tv showing blue screen with a small picture in red of a key... can u plz help me how to remove this and get my regular cable tv back on...
Hi msvkam
To answer your question;
You probably have the parental lock on,
Here`s the procedure and factory default code to unlock it:
Pass Code Menu
This menu allows you to change the access code for the Parental Guide
functions of the TV set. Pressing the .Menu. key when Pass Code
Control is highlighted. This will turn on or off the Pass Code function. With
the Pass Code function ON, you can also change the Pass Code. Use
the down arrow key to highlight .Pass Code,. then enter the new Pass
Code using the numeric keypad. Press the left arrow key when finished.
1. The factory default pass code of 6688 is also the override code, in case you forget your new pass code.
Hope this help,
Cheers
Jun 29, 2010 | Apex Digital AT2702 27" TV
I have a tv with the child lock activated , is there a way to override or reset this
hello If you forget your secret code, use the factory code 7777 to erase your key number. This will reset the secret code number back to the
factory preset 0000.
Press EXIT to quit menu or cursor F to return to previous menu good luckshaun
Sep 10, 2009 | Hitachi 50GX30B 50". Rear Projection...
Need code to program direct tv for truetech tv
here is a list of all of the direct tv codes. I do not see your TV on the list, which is sometimes the case. Maybe you will find it there. Hope so.
http://2getdtv.com/directv/tv_codes.html
May 01, 2009 | TruTech PLV16320 Television
Trutech 16190 no remote
Try the Universal remote control URC-R6 it works fine with my Truetech.
The bad thing about my Truetech PLV16190 19" Flatscreen, 30days after I purchase the remote the tv went out. Screen Black, but sound works fine.
Feb 05, 2009 | TruTech PLV16190 Television
Don't know code
Press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired. • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels
Jan 04, 2009 | Apex Digital PF2020 20" TV
REMOTE FOR A TRUETECH TV?
Yes philips and samsung universal remotes can be used with truetech tv's. Trutech is a daewoo product so using a daewoo so try the daewoo codes and one should work for your tv.
Jan 01, 2009 | Universal Remote Control DIRECTV Universal...
Unlock apex tv model # AT2702
try this manual;
[PDF] AT M C T
On the remote try pressing the ( F ) button and the mute button at the same time on your remote control.
Here's the link for the 2402s manual:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=4db1185db9d3369
Pass Code Menu
functions of the TV set. Pressing the “Menu” key when Pass Code
the down arrow key to highlight “Pass Code,” then enter the new Pass
2. The factory defaults have TV-MA and MPAA-X ratings blocked . Hope this may help you
DON'T FORGET TO RATE:
Apr 17, 2008 | Apex Digital AT2702 27" TV
TruTech PLV16190 Television Logo
1,069 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
