Question about Sharp Office Equipment & Supplies
I want to know that how to adjust exposure level in sharp 1118 or how to make light copy with diganostics mode
    Guru:
  • 389 Answers
L For manual copy density adjustment, press the AUTO/
MANUAL/PHOTO ( / / ) key to select
MANUAL ( ) and adjust with the LIGHT ( ) and
DARK ( ) keys as desired.
l For photographs, select PHOTO ( ) and then adjust with the
LIGHT ( ) and DARK ( ) keys as desired.
l There are 9 exposure steps indicated by 5 indicator lights. (The
indicators light up one or two at a time.)
Successive pushes of the LIGHT ( ) key will change the
indicator lights in the order (3) / (3•2) /(2) / (2•1) / (1).
Successive pushes of the DARK ( ) key will change the
indicator lights in the order (3) / (3•4) / (4) / (4•5)/ (5)
The automatic exposure level can be adjusted to suit your copying
needs.
1 Press the AUTO/MANUAL/PHOTO ( / / ) key
to select the PHOTO ( ) mode.
2 Press and hold the AUTO/MANUAL/PHOTO ( / /
) key for approximately 5 seconds.
l The PHOTO ( ) indicator will go out and the AUTO indicator
will begin to blink.
l One or two exposure indicators corresponding to the automatic
exposure level which has been selected will light up. The factory
default setting is level “3”.
3 Press the LIGHT ( ) or DARK ( ) key to lighten
or darken the automatic exposure level as desired.
4 Press the AUTO/MANUAL/PHOTO ( / / ) key.
l The AUTO indicator will stop blinking and will light up steadily.
l This automatic exposure level will remain in effect until you
change it again by this procedure.
Automatic exposure adjustment
AUTO
Posted on Sep 15, 2009
Fax machine not copying coming out very light what would it be
Select an appropriate exposure mode for the original being copied and adjust the exposure level manually.
May 27, 2016 | Office Equipment & Supplies
SHARP AR-M455, AUTO-EXPOSURE
Press custom settings, then go to key operator settings. The default log in is 00000. Then go to ccopy settings, default, exposure adjust.
Jul 16, 2012 | Sharp AR-M455N Copier
Sharp Photocopier 2114 makes all black copies
OPEN top cover make a copy see if copy exposure lamp turns on or not
May 25, 2010 | Sharp AR-5320 Black and White Copier
I HAVE A SHARP AL 1641 CS COPIER AND THE DRUM I WAS GIVEN WAS SHARP AL 1000 DRUM UNIT AL 100 PART MS1DR AND THE DRUM LIGHT IS STILL ON AND THE COPIER WON'T WORK, DO I HAVE THE RIGHT DRUM AND IS THERE...
The AL1000 drum unit is the same as the AL1641 drum.
I do not recognize the MS1DR as a sharp part number.
You can reset the drum indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
This should make the copier operational again if all you have is the drum light.
Dec 02, 2009 | Sharp AL-1641CS Laser Digital Copier
How to get the copy counter on the display?
Press the stop/reset key, start key
and the left copy exposure adjustment
key in the order presented and hold
them down.
Press the stop/reset key. entering service mode.
Enter the number of the maintenance
item to be executed using the copy
exposure adjustment keys or the zoom
+/- keys
enter 000 start to print staus report.
Do not change any settings...only use 000 to print report, then 001 to exit service mode after it has finished printing.
This is very important so that you dont render your machine useless.
To exit service mode-
Enter 001 using the copy exposure
+/- keys, and press the start key.
Jun 05, 2009 | Kyocera KM-1505 Copier
NP7161: we include - blazes "id"; what throw?
Necessary entering the identification number of the access; the unset: Head - ID - a foots - a head - (on дисплее will appear ID1) - 2 - a start - (on дисплее 2-1) - 0 - (on displey 2-0) - a start - (the codes of the users delete) - ID possible to copy.
NP7161 - a regulation AE
Adjustment AE: -User mode 12 - an the man picture, 12. then - a button "+/- exposure" (24 steps); "Start" - a taking the change
May 16, 2009 | Sharp AR-5316 Advanced Digital Imager...
Pitney bowes c180
Try making a copy in Photo mode and see if it makes a difference
Nov 18, 2007 | Sharp AL 1631 Copier
Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Sep 14, 2007 | Kyocera RI-3530 Black and White Copier
Copies are too light and nothing is working
Probably needs a good cleaning. The mirrors get dusty. I would suggest you call a tech. to do it. As you can nock something out of wack.
Jul 24, 2007 | Sharp AL 1631 Copier
Sf-1118
does the same occur when the manual paper feed path is used?
Apr 08, 2007 | Sharp AL 1215 Black and White Copier
234 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
