Question about Maytag Dryers
Hi, we have a Maytag Electric Dryer models DE313 ,i beleve it has a bad bearing in the rolary drum ,i see the top should come off by pushing rearwords ,it dont seem to move how should i get it off ? Please let me know thank You
    President:
  • Maytag Master
  • 1,922 Answers
Depending on model maytag take off frt cover then youll find screws for top cover to remove on frt panel chk toward top and just off floor they're usually at a 45 degree angle pointing up for looks so you wont see them at first
Posted on Jul 29, 2009
WORN BELT ON MAYTAG ELECTRIC DRYER
Remove the two brackets on the back holding the top on. Then pry the front part of the top off with a flat screwdriver. Next remove the electrical connectors. The remove the front panel. Then pull the drum out. Install the belt and push the drum in place placing the belt correctly into the tensioner for the belt
May 10, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Neptune MDE3000 electric dryer replacement of belt
The top comes off then the front panel is next.
remove the drum by pulling it out to replace the belt. replace the tensioners pully as well for it has a bearing that wears out then squeals loadly when old and dried up
Mar 27, 2010 | Maytag Neptune MDE4000 Electric Dryer
I have a Maytag dryer model de313 sometimes it does not start the other times it starts but there is some sort of screeching noise
it could be the belt is broken or the berring have broken too, best to turn of the power, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing.
Mar 09, 2010 | Maytag Dryers
I Have a maytag Electric Dryer the dryer is
it could be your drum glides in the front of the drum or the rear center bearing or rear rollers, or the belt idler pulley or motor end bearings going bad,you will need to remove the front cover by removing lower kick panel screws near the floor and lifting upward on front cover,then remove top cover screws located under top cover and lift up and secure so as not to break wires to control panel,then rotate drum by hand and listen for noise location
Jan 25, 2010 | Maytag PYE2300AY Electric Dryer
Belt Change on a DE313 Maytag Dryer
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Jul 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Loud banging noise while drying
the Idler bearing maybe going. its fairly easy to replace. go here http://www.repairclinic.com/Maytag-Dryer-Parts?s=b4a8c203
the part is cheap and i will show you how to remove the front door and replace the bearing.
May 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
User manual for Maytag DE313 Series 107
(Click below for user manual)
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=RF262LXSB0&siteCd=WHRCOM
The age of your dryer I'm not sure, The elements for your dryer can be found below, go to my web-page and enter the model DE313 into search feature and you will get pictures of the parts. The element part# is Y313538 (click link below)
http://servicepartstec.blogspot.com/
If you need help, just let me know,Thanks,Sea Breeze
Mar 23, 2009 | Maytag Dryers
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Noisy maytag dryer
the blower wheel sounds like it is bad it should be tight on the shaft and not turn unless the tub turns
Nov 15, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
171 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
