Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
Saw runs good when you prime it cant get it to get gas from tank
  • 99 Answers
Sounds like you have a plug between the tank and the carb. I would change the hose between the two and clean the tank as well as the carb.
Posted on Jul 30, 2009
Tiller will not continue to run. It has good spark. It will start if primed through the carburator but once the prime burns off it dies.
If fuel sits in the gas tank 3 months, the fuel deteriorates and it gums up the filter in the tank. You need to put stabil in the tank. This has happened to me over and over. It is best to dump out the gasoline if you don't use the tiller within one month. Some people who use chain saws commercially dump all the gas out every day and start over the next day. The symptoms are the tiller won't run at high speed at first, then as it gums up more
it won't run even at low speed, then becomes hard to start.
The gum is hard to see. Pull out the gas line to get to the filter and change the filter. Filters are only 3 or 4 dollars at hardware stores.
Jun 01, 2012 | Honda 25cc 4-cycle Mini Tiller
I was using the saw when it suddenly seemed to run out of gas, the tank was full and I attempted to prime it as there was no gas visible in the primer button. I have refilled the tank and tried priming it...
Remove the carburetor cover and inspect all fuel lines for coming loose on the carburetor and the primer. If nothing is obviously wrong, return the saw to where you bought it to obtain warranty service. Hope this helps!
Jan 05, 2011 | Makita DCS46018 Commercial Grade 18Inch...
Ok in order to pour gas in what i called the "carb" i have to take some sort of breather off. i have a 2000 chevy blazer 2wd cyl vortech is it the fuel pump gone bad or could it just be out of...
turn key on and listen for fuel pump in the tank, it should go on for a few seconds then turn off. if you cant hear it try to listen at the fill cap when someone else turns the key on. if you cant hear it , check the safety shutdown relay under hood, it shuts down fuel pump and ignition
Jan 04, 2011 | Chevrolet Blazer Cars & Trucks
Chainsaw ran out of gas. Filled tank will not start now. Husqvarna 450 e=series 18"
Those saws are very finicky. First shake the saw very vigorously, as the saw running dry mayy have sucked dirt to the intake screen. Clean the plug and check gap. Prime, choke and pull till it starts. your plug may be foulled, this happens alot when a saw leans out from running out of fuel.
Jul 22, 2010 | Husqvarna 450 e-series 18" Chain Saw
Starts then shuts off in 30 secs saw is pretty new
gas issue, saw chokes out. look in your gas tank and make suri your line runs all the way down. follow the lead and make sur both leads connect do this by pressing prime and making sure the pressure is channeling.
Oct 19, 2009 | Garden
I have a Benchmark chain saw - replaced brittle fuel lines
sounds like your clunk has come free from fuel line or it is stuck at top of fuel tank. i would empty tank and see if clunk is free by giving the saw a good shake if you cant here the rattel of the clunk you have found the problem PS clunk is a weight attached to the end of your fuel line in tank it makes the line stay at the bottom of the tank
Sep 05, 2009 | Garden
Cant figure out where fuel lines go on mccullogh chain saw
Fuel lines: one comes from the tank...has a filter in side the tank...runs up to the intake of the carb... you can tell by hooking up the lines to the carb, and put one into a gas supply... press the prime bulb... if it pulls gas, thats the one to hook into the tank...if not it 's the other... there should only be two lines a fuel supply and a return pressure line. Clean the air filter while you've got it apart....
k
Jul 01, 2009 | McCulloch 26cc Gas Blower Mcb3208
Chain saw wont start after running out of gas?
Hi
Fill the gas tank with new fuel.Priming the engine(put some gas in the sparkplug hole for few times and start the engine until it runs constantly):There is small amount of water in the gas.
best regards savumihai71
Dec 27, 2008 | Poulan Pro Chain Saw 46cc 20"
455 Husqvarna chainsaw will not run
Remove exhaust , check piston make shore you have a chance,
check ex screen isn't blocked.
check choke isn't stuck on,and half throttle is working. get back to me from there.cheers
Dec 22, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Saw will not start Husqvarna 350
Hi
An engine needs three things to run(fuel and air mixed together in the correct proportions,compresion of the fuel/air mixture and ignition).Make carb adjustments,check the compression and the spark from the sparkplug.Priming the engine(put some gas into the sparkplug hole).Try to start the engine.If engine is running only the gas from the cilinder,the chain saw has a fuel delivery problem.Disassembly the carb and clean the inner parts.Check the fuel and air filters,fuel hose and gas tank ventil.
good luck!savumihai71
Dec 04, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
100 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
