I have an older 4 port linksys router. I recently upgraded to Explorer 8. Now neither computer can get to the Internet when using the router. They can connect if I go from modem to each PC separately. Each computer can print through the router. Each computer can "see"the other one.
  • 135 Answers
Check the gateway settings on the machines, which is supposed to point to the router's IP. also check the DNS settings on the machines.
Posted on Jul 27, 2009
Tip
How to Upgrade Firmware of Linksys routers........
As the application requires certain ports to be opened on the router,try to follow the steps below to configure the router. Since you are connecting behind the router, you are going behind a NAT firewall.Therefore, you would need to allow ports for the remote access application to go through the firewall. You would need to know what port number application uses. You can check with the program manufacturer for the information, or see the Help menu.
For routers with old firmware versions (without the Cisco web interface):
1.Open Internet Explorer.
2.After "Internet Explorer" opens, please typehttp://192.168.1.1 into the "Address Bar" and click GO.
3.The "Enter Network Password" window will appear. Skip username and type admin (admin is the default password) as the password,and click OK.
4.You will need to click on the Advanced tab to the very right. Once the "Filters" area appears, please click on the Forwarding tab.
5.Once the "Forwarding" area appears, click the Port Triggering button. Once you've done this, a new window will appear.Enter the ports needed to be opened > Click Apply
For later firmware (that has the Cisco web interface)
4.Click on "Applications and Gaming" then click on the "Port Triggering" Sub tab. Enter the ports needed to be opened >Click Save Settings.
Example:
Customized Trigger Port Range Incoming Port Range
Application From ~ To From ~To
WARCRAFT 6112-6112 6112-6112
WARCRAFT 6113-6119 6113-6119
Hope this help everyone that has problem with the game.
on Jan 05, 2010 | Linksys Wireless-G WRT54G Router
I have RV082 Router , and Diag Led is constant what to do
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router, the following should be lit:
  • 1 - 8 (LAN)
  • DMZ/Internet (WAN2)
  • Internet (WAN1)
  • Diag
  • System
Step 1:
Make sure the System LED is lit.
NOTE: If the Diag LED doesn't goes off, you need to upgrade the router's firmware. For instructions, click here .
Step 2:
Make sure the LAN 1-8 ports is lit depending on the computers connected to the designated Ethernet port.
NOTE: If the LAN 1-8 port is not lit, make sure that the computer is powered on. You can also try connecting the PC using another working cable.
Step 3:
Make sure the Internet (WAN1) and DMZ/Internet (WAN2) LED is lit.
NOTE: If the Internet or DMZ/Internet LED is not lit make sure the Broadband modem is powered on and that the modem is properly connected to the Ethernet port
You can access the web-based user interface utility of the RV082 by using one of two methods:
  • Through the RV082 IP address (192.168.1.1 by default), or
  • Through its default hostname ("RV082")
1. Open a web browser (Internet Explorer or Netscape Navigator)
· By IP address: Type http://192.168.1.1 (192.168.1.1 is the default IP address of the RV082)
and click Go or press the [Enter] key.
· By Hostname: Type http://RV082 and click Go or press the [Enter] key.
2. When the username and password prompt appears, type admin in both the username and password fields. (admin is both the default username and default password for the RV082).
Nov 08, 2010 | Linksys RV082 Router (RV082-AU)
I lost the instructions on how to install a Linksys wireless router. I would like to down load these instructions.
cable setup
This guide is recommended for Cable Internet Service in the USA like Charter, Cox, Comcast, Cable Vision, etc.
  1. First you need to connect the device together. You need to connect your cable modem to the internet port on the back of the router, and the computer should go to one of the 4-port on the router labeled Ethernet (1, 2, 3, 4).
  2. Then turn on the modem first, wait for the lights to stabilize before powering on the Linksys router. Lights that you should have on the router are Power (solid green), Wireless/WLAN (Green sometimes flashing), One of the no. lights where the computer is plugged in (flashing), And the internet light (flashing).
After doing this step there are times that this will already get you online. If the internet will not work, you continue following the steps 3.
3. If the internet is still not working; we will need to adjust a setting on the router setup page. To access the setup page of the router you need to open your internet explorer or Firefox on the computer that is hardwired directly to the router. In the address bar of your browser (Internet Explorer or Firefox) type http://192.168.1.1/ and hit enter or click Go. It will ask you for a username and password. Just type "admin" for the password field and there is no username. If you have ran the setup CD prior to this, then use the password that you have set when were running the setup CD.
4. Once you are in the setup page of your router make sure that the Internet Connection Type is set to Automatic Configuration DHCP, then click the save the settings button at the bottom of the page. After saving the settings, click the sub tab at the very top of the page that says MAC Address Clone. Set it to enable and click the button that will say Clone or Clone your PC's MAC and save the settings again.
5. After doing step 4, do a power cycle. Power cycle is done by turning of the router, modem and computer. Leave them off for a minute, tuned them back on in this order. Modem first wait for the lights to stabilize, then the router wait until the power light become solid. Then turn on the computer. This will get you online through the router.
DSL
Configuring the Linksys Router.
These instructions assume the computers TCP/IP Properties are configured to " Obtain an IP Address Automatically"
1. Connect the Linksys power supply and connect a Lan port to the computers Lan port.
2. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP)
3. When "Internet Explorer" opens type »192.168.1.1[?] into the "Address" bar and click on Go
4. The "Enter Network Password" window will appear.
5. Skip user name and type admin (admin is the default password) as the password, and click OK
6. Scroll down on this page and look for (on older firmware) PPPoE or select the option for PPPoE under "WAN Connection type"
7. Username: yahootheclown@sbcglobal.net or yahootheclown@ameritech.net and your password.
8. Select the option for "Keep Alive" with a redial period of 180
9. Click on the Apply button.
10. Then click on the Continue button
11. Exit Internet Explorer
Power Cycling:
1. Shut down your computer
2. Unplug the power from the router
3. Unplug the power from the DSL modem
4. Wait for 30 seconds and re apply power to the DSL modem
5. Once the lights on the DSL modem stop blinking power up the router
6. Start up your PC
Checking your internet Connection:
1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP)
2. When "Internet Explorer" opens type »192.168.1.1/Status.htm[?] into the "Address" bar and press the "enter" key or left click the "go" button
3. The "Enter Network Password" window will appear.
4. Skip user name and type admin (admin is the default password) as the password, and click OK
5. On the left of the "Status" page you will see "PPPoE Enabled", and to the right you will see the Status of the connection. It can be one of the following:
- Disconnected
- Connecting
- Connected
6. If the status is "Connected" you should be able to browse the web, if not reboot your computer
7. If you get an error message please repeat the "Configuring the router" and "Power Cycling" steps with a different username.
- If all four connections fail then please see our knowledge base articles on the error you're getting.
Once the router is configured correctly you should change the default password and record it for reference.
You should also add the "Enter Network Password" page to the Favorites List, and review the user manual.
for linksys tech support call 1800 3267114
hope this helps.
Oct 18, 2008 | Computers & Internet
HELP
cable setup This guide is recommended for Cable Internet Service in the USA like Charter, Cox, Comcast, Cable Vision, etc.
DSL
Power Cycling:
6. Start up your PC
- Disconnected
- Connecting
- Connected
hope this helps.
Oct 16, 2008 | Linksys Wireless-G WRT54G Router
I purchased a wireless router model wrt110 early this month, installed and working fine unitl last night had to uninstall and tried to install it back i get to the installation to figure the router and i...
NO need to worry i will provide a valid trouble shooting steps
I think u have used the set up cd..dont use the Cd..i will give u the exact steps..
U dint specify that whether u r using the cable Internet or DSL!!
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the router)
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or ball point pen,press it hardly and hold it for 1 minute..
4,Now turn off ur modem and the router..wait for other 1 minute..
5,turn onn only the modem and wait till all the lights lit.now turn on the router and wait till the power light is solid..open the internet Explorer it should work..
STeps for DSL Connection(verizon)
6,open internet Explorer and in the address bar..enter as 192.168.1.1..it will prompt for a user name and password..leave the user name blank and the password will be admin.
7,linksys set up page will open..there u can see local ip address which says 192.168.1.1.
please change it as 192.168.2.1..click on save settings at the bottom of the page..
it will say like "settings are successful please release and renew the ip address".click continue or OK
8,Now turn off ur modem and the router..wait for other 1 minute..turn onn only the modem and wait till all the lights lit.now turn on the router and wait till the power light is solid.
9, Open Internet Explorer and it shuld Work....
TRY IT AND GIve me ur feedback
May 31, 2008 | Linksys Wireless-G WRT54G Router
Help
hello!
-- who is ypur internet service provider?
-- what is the operating system of your computer
you may try ff and see if this may help you solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this didnot work try upgrading the firmware of your router
Apr 28, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Setting up Comcast High Speed Internet with a Linksys Router
The following article will describe how to setup Comcast High Speed Internet with a Linksys Router: Connecting your cable modem to the Router 1. First connect directly to your Cable modem without the router and verify that you can get on line. 2. Once you've verified that you can get onto the internet without the router please proceed. If you can not please contact your ISP for further assistance. 3. Now unplug the Ethernet cable that connects to your DSL modem from the back of your computer. 4. Take the connection that you just unplugged from the back of your computer and connect it to the WAN port of the router. 5. Take a different Ethernet cable and plug it into port closest to the WAN port, or into the LAN port. 6. Look on the front of the router. The following lights should be illuminated: - Power - WAN Link - Link/Act (On the port that you connected your computer to) - Note If other lights other than Link/Act are illuminated on this port, that is normal - You may have a few other lights illuminated depending on the model number router you have, but the 3 above must be illuminated for proper connection. 7. Hold the Reset button on the router for 30 seconds or more 8. Restart your computer Checking the MAC address of your Computer Please follow these steps from the computer that was connected directly to the internet with out the router. If you do not, then you may not be able to connect to the internet properly. A. Windows 9x/ME 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in winipcfg and click the OK button 3. When the "IP Configuration comes up" click on the gray box the black arrow and select your Ethernet card. 4. Please make note of the "Adapter Address" B. Windows 2000/NT/XP 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in cmd and click the OK button 3. When "Command Prompt" appears type in ipconfig /all 4. Please make note of the "Physical Address" Configuring the Router 1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP). 2. When "Internet Explorer" opens type http://192.168.1.1 into the "Address" bar and click on Go. 3. The "Enter Network Password" window will appear. 4. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. By default the router will be set to Obtain an IP Address Automatically. 6. Click on the Advanced tab. 7. Click on the Mac Addr. Clone. 8. When the page loads, input the Adapter/Physical Address you made earlier and input it into the proper fields. 9. Click Apply Finishing the Setup 1. Shut down your PC. 2. Unplug the power from the back of the router. 3. Unplug the power from the modem. 4. Wait for 30 second. 5. Power up the modem. 6. Wait for the lights to stop blinking. 7. Power up the router. 8. Start up your computer. 9. Surf the internet. - *Note: If you are still unable to get on to the internet please repeat from step 1.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
How To Set Up PPPoE DSL Connections with a WRT55AG Router
STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to clear the ?Password? field before entering your account password. AOL USERS: Enter in your PPPoE username as screenname@aol.com. 6. If the Keep Alive option is not selected, be sure to select it instead of the ?Connect on Demand? option. The ?Keep Alive? option will ensure that your connection stays connected even when it is not in use. 7. Scroll down to the bottom of the page and click on the Save Settings, or Apply button depending on router model, to save your changes. OR 8. Once your changes are saved, you will be presented with a button to return or you will be returned to the previous page automatically. If prompted, press Continue to return to the router?s Setup page. 9. Close and exit the web browser. STEP 5: Power Cycle Follow these steps to power on and off your devices in the correct o
Feb 16, 2006 | Linksys WRT55AG Router
The following article will describe how to setup Comcast High Speed Internet with a Linksys Router: Connecting your cable modem to the Router 1. First connect directly to your Cable modem without the router and verify that you can get on line. 2. Once you've verified that you can get onto the internet without the router please proceed. If you can not please contact your ISP for further assistance. 3. Now unplug the Ethernet cable that connects to your DSL modem from the back of your computer. 4. Take the connection that you just unplugged from the back of your computer and connect it to the WAN port of the router. 5. Take a different Ethernet cable and plug it into port closest to the WAN port, or into the LAN port. 6. Look on the front of the router. The following lights should be illuminated: - Power - WAN Link - Link/Act (On the port that you connected your computer to) - Note If other lights other than Link/Act are illuminated on this port, that is normal - You may have a few other lights illuminated depending on the model number router you have, but the 3 above must be illuminated for proper connection. 7. Hold the Reset button on the router for 30 seconds or more 8. Restart your computer Checking the MAC address of your Computer Please follow these steps from the computer that was connected directly to the internet with out the router. If you do not, then you may not be able to connect to the internet properly. A. Windows 9x/ME 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in winipcfg and click the OK button 3. When the "IP Configuration comes up" click on the gray box the black arrow and select your Ethernet card. 4. Please make note of the "Adapter Address" B. Windows 2000/NT/XP 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in cmd and click the OK button 3. When "Command Prompt" appears type in ipconfig /all 4. Please make note of the "Physical Address" Configuring the Router 1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP). 2. When "Internet Explorer" opens type http://192.168.1.1 into the "Address" bar and click on Go. 3. The "Enter Network Password" window will appear. 4. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. By default the router will be set to Obtain an IP Address Automatically. 6. Click on the Advanced tab. 7. Click on the Mac Addr. Clone. 8. When the page loads, input the Adapter/Physical Address you made earlier and input it into the proper fields. 9. Click Apply Finishing the Setup 1. Shut down your PC. 2. Unplug the power from the back of the router. 3. Unplug the power from the modem. 4. Wait for 30 second. 5. Power up the modem. 6. Wait for the lights to stop blinking. 7. Power up the router. 8. Start up your computer. 9. Surf the internet. *Note: If you are still unable to get on to the internet please repeat from step 1.
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
