Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Frigidaire FRS23H5SB6 side-by-side freezing food
We had a repairman come out to hook up the water line and repair the ice machine (we just bought the house). He reset us to 'factory settings'. Everything in the fridge (especially items in the bottom) froze solid.
We adjusted the settings in the fridge and freezer to almost "0" and it helps, but things are not all that cold at the top of the fridge and will still freeze at the bottom.
Help!
  • 4,059 Answers
It sounds like the fan in the freezer behind the rear panel is not working. You should be able to hear it. It won't run with the door open so hold the door switch in.
Posted on Aug 09, 2009
Frigidaire FRS26HF6BW2 side by side Refrigerator with ice maker, no water flow. Everything was working fine until the food in the refrigerator started freezing. Freezer stable at 0F and refrigerator...
Memory card is not opening and when i connect in pc so they show error like.. there was a problem starting -WKBPBCM.init the specified module could not be found.... so please solve my problem
Oct 31, 2013 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS26LF8CS3 Side by Side, Freezer ice/cream melting, lower bin food side freezing
(There is a defrost heater on the evaporator in that area.If
you have a VOM you could check it with the power plug pulled out of the wall socket)
if you access the area turn the defrost timer on (clockwise)it should get warm in that area and you shoud hear a popping sound
If you want to tackle the job for yourself all the manuals are here
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FRS26LF8CS3&User=&Search=Search
Nov 27, 2007 | Refrigerators
Frigidaire FRS26R4CW1 icemaker not working and food freezes in refrigerator
Contact a tech professional to diagnose the unit. You could have a floating restriction in the coolant lines and cannot easily be found on your own.
Aug 05, 2012 | Frigidaire FRS26R4C Side by Side...
All the food in my fridge is freezing. ihave checked temp gauge. it is set to normal setting. what could it be i have troubleshooting it for days HELP
Hi
Food freezing in the refrigerator can be caused due to various reasons,please check this links bellow to troubleshoot your problem:-
http://www.partselect.com/refrigerator+fridge-freezes-food+repair.htm
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#thefoodintherefrigeratorfreezes
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
E had a power outage due to a storm blowing trees down on power lines. When the power returned, about 4 hour later, the refrigerator/freezer (side by side) was making a loud buzzing noise. The ice maker is...
This sounds to me like a busted compressor, nothing more you can do to it. You must call a repairman to test it and replace it, a very delicate procedure that requires specialized equipment.
Jun 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire refrigerator, ice maker
If the ice maker is doing the normal cycle and when calls for water doesn't get any,probably the fill tube to the ice maker is clogh with ice because the dual valve (solenoid) is leaking and this water freezes up clogging the fill tube , or the solenoid doesn't work ,in both cases it has to be replaced(it's located in the back of the refrigerator attached to the water supply line).
Aug 28, 2009 | Frigidaire FRS3R5EMB Side by Side...
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Kenemore side by side refrigerator made by Frigidaire freezing everything in fridge
on some models you can by pass the filter assembly you can do this by looking at the rear of the ref.at the water inlet valve you will see the lines going to the filter remove these line and look at the way the water goes into the ref you can move these lines around to bypass the filter this will tell ya if the filter assembly is bad I have seen where you cant use the filter on these machines and have to go to a in line filter.good luck and get back to me on this i will help you as much as i can
Jan 07, 2008 | Sanyo SR-3620 Compact Refrigerator
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
278 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
