Question about Delphi Roady XT XM Radio Receiver
Background noise (high pitched whistle, and buzzing w/ rpm)
There is a high pitched background whistle noticed even when the engine is not on. Turning down the treble helps, but why is it there in the background?
With the engine on, there is a buzzing that follows the engine rpm, like electromagnetic interference from the alternator. I have moved the antenna to the rear window, but the background noise is still there.
4 Suggested Answers
SOURCE: A/C Adapter Noise and Interference
I had the same problem. Worked around it by going through the cassette tape adapter. Seems to have solved the problem.
Posted on Nov 09, 2009
TOLhamRadio
  • 509 Answers
Just wait until you're over 60; my kids can hear the high pitch, but I can't! You could try another power supply, but it has to have the 2000MA or 2AMPS of power to fire up the unit.
Posted on Feb 27, 2013
  • 7 Answers
AC wall adapter was failing for me. Car adapter worked OK. Found a 2A 5V adapter and changed the connector with success. Again hearing occasional beep but in car, no explanation found. Have had several good years of service; should not complain.
Posted on Jan 07, 2017
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
Is a high pitched whistling sound at idle a vacuum leak or what?
hissing vacuum leak at idle, louder with open throttle ...
? 1:43
https://www.youtube.com/watch?v=tFoybr865n4
Jun 27, 2010 - Uploaded by fenixus
hissing vacuum leak at idle, louder with open throttle ... i know that my camera is poor and microphone suppresses high pitch ...Hi, my kia picanto engine also sound hissing/humming duringidling with open throttle. ... Loud whistling noise 2000 jeep wrangler 4.0l - Duration: 4:01. by Nasrac72 16,158 views.Missing: vt750c
A Whistle or metal sound with firing... - Honda Shadow Forums ...
www.hondashadow.net > ... > Technical Discussion
Jul 11, 2008 - ... under load (accelerating), that there is a small whistle or even 'tap on metal' high pitch sound ... Pics of my 2008 Shadow Aero 750 (VT750C ... loose bolt vibrating
Feb 29, 2012
High pitch whine
Jul 21, 2009
More results from www.hondashadow.net
Dec 25, 2015 | Goes Motorcycles
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
Whistle noise
A whistling noise can be generated by an alternator at high RPM's and indicates a slip ring brush problem or a diode failing . It resembles a frequency whistle.. IT may also be from a leaking gasket and a partially blocked exhaust system from a failed cat converter and at speed and power, the exhaust gas is forced out the hole
Dec 26, 2013 | 2012 Acura TL Base Sedan 3.5L V6 6-speed...
I have a 2003 Jeep Wrangler that has a high pitch SQUEALING sound when I release the accelerator. Any ideas what's causing it or how to fix it?.
I know i have the same problem, and i also noticed than when i open the Hood the whistle just stops, so i figure out it must be some air cycling in or out osmewhere, I found out my air intake connected to throttle body was misplaced a weird gap was left open allowing air to whistle. u might wanna check there
Sep 19, 2012 | 2003 Jeep Wrangler
Emits high pitched whistling after unit runs for 30 minutes
Sounds to me like the bearings are going bad in the motor. The hotter it gets the grease breaks down and the squealing starts.
Jun 30, 2017 | Haier CPRB07XC7 Portable Air Conditioner
My brand new Whirpool front loader 1073DD makes a high pitched whistle when starting to spin and spinning, is this normal?
That actually is a normal sound, The machine is spinning at such a high speed rpm that a whistling noise is a common occurence.
Jun 14, 2012 | Whirlpool Washing Machines
At all speeds when you turn the throttle even just a little, you hear a high pitched whistle. Could anyone tell me if this is normal or not??
The noise may be the classic Yamaha whine. I have had a Virago & Vstar1100, They all had various noises that came from within. You may notice the distinct whine/whistle at lower speeds and during acceleration. Seems to go away if you pull in the clutch or let off the throttle, not so noticable on the freeway. This appears to be a common phenomenon and I have seen it attributed to Clutch, transmission, and/or shaft on a lot of Yamaha bikes.
I hope this helps.
Jul 02, 2011 | 2005 Yamaha Royal Star Tour Deluxe
Service engine soon indicator on and a buzzing/whining noise.
i recommend that you take it into auto-zone or a car shop asap. from what you have described the ticking as, it sounds like a bottom knock. as for the whine i don't know.
May 14, 2010 | 2005 Nissan Xterra
High pitch tone from my 2001 chevrolet S-10 pickup
You didnt indicate whether you ran the engine with the belt removed while replacing the alternator,if not do so and verify noise. Sounds like you may have a vacuum leak, best way to diagnose would be with a smoke machine if not available with the engine cold try spraying carb cleaner around the intake & any suspect vacuum hoses with engine idling look for a change in idle speed or elimination of noise. Hope this helps you out
Apr 10, 2009 | 2001 Chevrolet S-10
Delphi Roady XT XM Radio Receiver Logo
232 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
