Computers & Internet Logo
Roy McKinney Posted on Jul 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The first of four led lights FLASH ON and 0FF ON A970-G46 MOB AND MY POWEER SUPPLY TESTS GOOD. All componets work good on my 2nd identical MSI MOB. CAN THIS MOB BE FIXED OR MUST I REPLACE IT?
Larry Ng
Level 3:
Top Expert:
  • MSI Master 14,563 Answers
  • Posted on May 23, 2022
Larry Ng
MSI Master
Level 3:
Top Expert:
Answers
14563
Questions
0
Helped
3274078
Points
66461
Four led lights where are they? lost the manual? Desktop mobo.
MS-7693 (v2.x) Manboard
970a or 970S?
all led x4 status indicators. on mobo top
4 glow means phase 4 power level. page 32.
coin cell dead is #1 for all PCs over 5 year and for sure 7.
a dead mobo, bios screens dead, that it,????
what gpu card what monitor ?
all fans dead?
support for vista or w7 , so that?
bios HOT KEY IS <del> THEN F11 (BIOS II)?
2 MOBO 1 GOOD 1 BAD USING SAME CPU AND 1 STICK OF RAM.? same PSU>? wired same to mobo?
THIS MOBA HAS NO VGA IGPU PORT ON REAR SO MUST HAVE GPU CARD or there can be video ever.
and see bios.
and reset bios first and new coin cell first.
7years old that coin is and will be a pain now or soon. a $ 1 fix.
gpu card into top x16 slot?????
GPU card over 75watts must have gpu aux power wired to it or it will be dead, from PCl.
psu wired to JPWR2 ? must be. and JPWR1 both. or cpu will be dead.
that is about it , on this 2011 mobo.
no gpu card top in fact full speck on all things connected to the mobo no told, including all devices all cables, and cards. and port.
not told.
5 Related Answers
Anonymous
  • 310 Answers
  • Posted on Feb 26, 2008
SOURCE: Gateway 507 GR
Change your power supply.
ross schmolzi
  • 50 Answers
  • Posted on Dec 07, 2008
SOURCE: 99 discovery/ dies while driving
sounds like the belt is loose. if it has a tensioner check and or replace it, if not tighten the belt. or the alternator tests ok but is actually not working at low rpm. or the battery is shorted. electricity is tricky
Anonymous
  • 4234 Answers
  • Posted on Mar 03, 2009
SOURCE: No power on a Pioneer A-77X Amplifier
The unit is probably in protect mode. Do you have any electronics repair experience? If so, we may be able to work through this. Let me know and we will try a few things. You will need a multi-meter at a minimum.
Dan
Anonymous
  • Posted on Jul 03, 2009
SOURCE: pc can't boot up , no display , hdd led is constatly lighted
Check CMOS battery(Coin shaped battery), it should show 2.5-3V, if not then replace and check, you can even try and test the mbd without the CMOS battery. Some mbd does not boot with a faulty CMOS battery.
Anonymous
  • 127 Answers
  • Posted on Jul 08, 2009
SOURCE: my remote wont turn on A.C. and when I push manual
If the system does not turn on and there is not beep, it is either a low or overvoltage situation or a problem in the wiring. Check the 12VDC at thermostat and make sure that it is OK. Also, check the incoming 120VAC at the control box (unit with small phone cord)
Can't see picture in TOSHIBA LED TV, but still have sound and can see picture with flash light
try changing the back light inverter that's what light the screen some sets have separate back light inverter while some comes in he power supply...good luck
1helpful
I have a msi 785GM-E51 MOTHERBOARD IT FAILS TO POST AND THE FOUR PHASE POWER LED'S ARE LIT
Hello here is the home page:
http://www.msi.com/product/mb/785GM-E51.html#/?div=Driver&os=Win8%2064
If you download the manual you need adobe reader to read the content.
This could be a ram failure, or power supply.
Do you have another PSU you could try? This sounds like it could be the PSU or the RAM. Try using each RAM stick seperately, maybe one died.
All RAM can fail, brand RAM fails less often, but it can fail like the worst no name RAM out there.
Does there come any beebs when you press the power button ??
Good luck
My HP D530C does not power on. The power LED flashes 4 times. What is the fault? Pls let me know asap. Thanks.
HP xw6200 Workstation - Diagnostic LED Code: Four Flashes ISSUE: When the workstation is powered on, the front LED might flash red four times, once per second, followed by a two second pause. SOLUTION: The front LED flashing four times is a sign of a power failure. To fix this issue, complete the following steps:
  1. Open the access panel, and check to see if the four-wire power supply cable is properly connected to the system board.
  2. There may be a faulty device. Locate it by removing all devices and then reinstalling them one at a time until the workstation fails. Replace the device causing the failure. Continue adding devices to ensure all are functioning properly.
  3. Verify the power supply functionality, as follows:
    1. Disconnect AC power.
    2. Remove all internal power supply cables from the system board.
    3. Plug in AC power.
      • If the power supply fan spins, and the BIST LED illuminates, then the power supply is good. Replace the system board.
      • If the power supply fan does not spin, or the BIST LED does not illuminate, replace the power supply.
My tv will not turn on the green poweer light comes on then goes out
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck
2helpful
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Dan
2answers
5-yr old Maxtor 160GB fw/usb down
drives dead. Head crash problem.
The read head, has clattered the disk(s)
the only other option is to swap the logic boards over ( if they,re identical ) ** circuit boards on the drives**
Mike @ Compurepair.
How do hook up front panel power switch to motherboard
The simple way is to remove the front panel of the computer trace the wires to the front panel leds, make note of color pair to each led. The using the manual that came with the motherboard locate the schematic for the JFP1 connector on the motherboard, it show's where the leds wires connect to operate. If you have no manual, if you look very closely at the connector you will see where the led wires connect, you may have to use a magnifiying glass and flash light. You cannot damage anything if you accidently place the led wires in the wrong place. If the panel led wires are in a single connector and won't work on the motherboard, you can remove the wires from the connector by using a very small sharp pointed pick to push down the retaining tab on each wire, thus enabling it to be removed from the connector, just be patient. BPCS
4answers
Doesn't turn on, but LED blinks 5 times
The flashing light is an indication of the sweep falure. Most of the time it is in the sweep output section, like the flyback transformer and or the horizontal output transistor. Most of the time it is the flyback that causes all the problems and componet blowouts in these sony TV sets, but it is also sometimes the vertical output IC that shorts out the sweep power supply. In any case a solid state set is no where to be experimenting around with and should only be worked on by a trained service tech. Good Luck
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
