When i boot from bootable dvd/cd, nw8440 turns off after aprox. one minute. When i boot from HDD computer works fine. HDD & memory tests passed. All bios settings set to default value. HELP!
    Sergeant:
  • 173 Answers
When you power up the computer press F1 or
F2 or "del" key to enter in bios then go to boot option then check your cd or dvd rom is on first boot device.
also check your bootable disk is working fine.
Thanks for using fixya.
Posted on Jul 27, 2009
My hp xw4600 workstation beeps red light blinks on off
read the code the blink codes tell the story,
red lights where,
1: power button LED green? (can be red) and beeps
2: Monitor LED lamps?
3: caps lock on keyboard blink.
4: is the COIN cell dead? 2.9v to 3.3vdc good, lower volts is bad , as most are this old !!!
http://www.pcdied.com/intel-magic/xw4600.html
the service manual covers all this! ever heard of HP and there REAL pages,,???
why not read that?
(do the fans all spin, if not PSU is dead.
PSU fan is first. does it.
CPU fan , huge fan on heatsink must spin.
the stock GPU card has no fan (ASUSc card but mine does. at ATI card.as fan right on the express 16 card.
does the DVD drive eject work.
if any of the above fail the PSU is bad.
but we strip off all loads from the MOBO
to prove its not some part shorted. first.
the front LED on this PC has flash codes
mine flashes in sleep mode, or w10 power off.
w10 never turns power fully off, it uses hibernate to turn off, (unless i cure that, ask)
the factory manual starting on page 111 cover this.
fully.
i own this beast so .....
code 2 red is overheated.clean the PC and all fans.
code 3 red, processor errors CPU.
code 4 PSU dead or shorts on load buses of same.
we call them power rails, we bench test the PSU
or read page 111 , how.
code 5 = GPU RAM failure, this PC has on board, GPU chip only X16 slot card, replace it. or the DDR2 rams are bad.
code 6 = GPU card bad.
code 7= BIOS ROM, put in a new coin cell first.!!!
Code 8= BIOS, always do nee COIN cell first.
code 9 = cant boot hdd, hdd bad or software gone, or corrputed, PC can now boot to a linux live CD or USB stick proving now PC is ok,
only hdd and OS suspected now. code 9
coin.
http://www.pcdied.com/intel-magic/slots.jpg
page 111 is here, 24/7 !
http://h50146.www5.hp.com/lib/doc/manual/workstation/hp_workstation/WS_UG_xw4600_STRG_453080-001_screen.pdf
Sep 01, 2017 | HP Computers & Internet
My laptop gets the error pxe-e61 error and I do not have a bootable disk
Check your boot order. If it is set to network you'll get this error. It could also be due to bad cable, etc.
Error PXE E61 Media test failure check cable
It's a good idea to get a bootable USB that can run some utilities, as well.
Jan 05, 2015 | Toshiba Satellite Pro C850-10N 15.6-Inch...
No bootable device/ compaq laptop
Have you tried a System restore/recovery? Do you get any response when using the F keys at boot? Could be the HDD, reset the HDD first, if you still get no response, remove HDD and test.
Mar 19, 2013 | Compaq Computers & Internet
ACER ax3470 boot
restart computer and push F12 then select DVD/CD bootable device then you can use it DVD
Jan 17, 2013 | Acer Aspire Ax3470 Desktop Pc Amd A6 3420...
Power failure,command display (no bootable cd)
It seems that your first boot was on cd or dvd, or may be your hard drive did not detect, to check both of them go to BIOS set up by pressing F2 or Delete on your keyboard to enter set up. When you are in set up mode go to Boot menu (if you can not see boot menu go to advance). In a boot menu select HDD as a first boot and Cd or DVD as a second boot, if you can not find your HDD it means that your HDD did not detect, and you need to replace it with a new one.
Hope it gives you a solution
May 30, 2011 | Computers & Internet
Than you in advance for any and all help pertaing to my issue. Problem: 3-4yr old HP laptop. Did have Win XPsp2 on it. HDD went bad. Used Barts PE to create bootable cd-rom with half working Win XP, but...
Why do it the hard way? If your HDD is bad, most probably the system files are corrupted too and getting/making a bootable CD from the HDD files is just wasting your effort. If you laptop CD/DVD drive is still good, then use the options below: -
1. Go to any torrents site download "hp oem xp" disc from the site & burn the bootable image to a CDR.
2. Go the the Hp support Site & download the XP drivers for your Laptop model.
3. Then you can do a new installations on your Laptop.
Hope it helps.
Nov 15, 2010 | Microsoft Windows XP Professional
My laptop recognizes the CD-RW/DVD drive but it can't read any disk.
What Operating System are you running? Drive could be bad. If you have you a bootable CD (like your original setup disks) turn your computer on with the bootable disk in and see if it tries to boot from it. You may have to adjust your settings in the BIOS to set it to boot to disk before the HDD for this to work.
Nov 10, 2010 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Hp g60-120us computer will not boot, passes
hi
You need to set the boot seq to boot first from the dvd or cd drive, and try the dvd or cd in an other computer first!
May 30, 2010 | HP G60-120US Laptop
How to install operation system on a acer aspire 5610 laptop computer if setting is incorrect
you have to change the boot device order from BIOS from HDD to DVD/CD Rom..
Now insert a bootable disc and follow the instructions...
All u need is BOOTABLE DISK.
just follow the instructions & let it work....
Jan 02, 2010 | Computers & Internet
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
