Question about Epson FX 2170 Matrix Printer
Epson fx-2175 not supporting Times New Roman font in PDF document
When i try to print a pdf document which is having the times new roman font, the printer is not printing correctly.the print is not readable.when i print a text document with times new roman font ,the printer is printing it correctly and the it is readable.
please help me out in solving this problem.this is urgent.
  • kk2707 Jul 28, 2009
    Hi robert,
    I am using acrobat 9.0.
    Still the problem is there..
    Thanks,
    Kranthi
    Hi Robert,
    The issue is resolved.
    But its the other way.I have used Acrobat 6.0 and checked,the print is coming fine...
    Thanks,
    Kranthi
    President:
  • 627 Answers
I suggest to update your acrobat reader to a better version (e.g. 8)
As i know acrobat 7 has some font issues which you described
Posted on Jul 27, 2009
Acer aspire one zg5 no erecovery Pls Help.... Running on Win XP
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer.Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Sep 27, 2011 | Acer Aspire One PC Notebook
Tip
How To Remove and Install a MAP Sensor for Your 1988 Dodge Aries
REMOVAL & INSTALLATION
Chrysler Electronic Fuel Injection (EFI), Multi-point Fuel Injection (MFI) and Eagle Throttle Body Fuel Injection (TBI) Systems
  1. Disconnect the negative battery cable.
  2. Unplug the electrical connector from the sensor.
  3. If so equipped, disconnect the vacuum hose from the sensor.
  4. Remove the MAP sensor mounting fasteners.
  5. Remove the sensor from the vehicle.
To install:
  1. Install the MAP sensor into its position and secure in place with the mounting screws. Tighten the screws until snug.
  2. Connect the vacuum hose, if so equipped.
  3. Plug the electrical connector back into the sensor. Make certain that the connector is clean and snug fitting.
  4. Connect the battery cable.
on Nov 22, 2011 | 1988 Dodge Aries
Tip
How to Remove Scratches in Stainless Steel
Whether you can remove a scratch has much to do with how deep the scratch goes. Here are several ways to deal with this problem and restore your cookware, stainless steel appliances, countertops or sinks to their former glory.
Consider using a product made for stainless steel such as Scratch-B-Gone or Bar Keepers Friend.
Or, try spraying an all-purpose cleaner (such as Formula 409) on the scratches.
Use a non-metal scouring pad (such as Scotch-Brite pads) to rub the cleaner in, always rubbing in the direction of the grain.
Keep the stainless steel wet with the cleaner as you work, and rinse the pad often.
Rinse the surface and wipe dry.
You may also use a solution such as WD-40 to help fill in the sctraches and coat the stainless steel on the unit(s).
on Oct 19, 2011 | Frigidaire Refrigerators
I have an asus eee pc 4g (linux) and i want to change finnish languge to english. please help....
Changing Languages:
  1. Click on start
  2. Control panel
  3. Regional and language options, there you have the option to change the language to pretty much any language that you want
Sep 26, 2011 | ASUS Eee 4G Notebook
Times New Roman and Arial fonts problem.
What printer code page are you using on the printer?
Oct 26, 2009 | Epson FX 2170 Matrix Printer
Printing differently than what is on screen
TRY PRINTING THROUGH MS WORD. OPEN MS WORD - CLICK ON FORMAT - FONTS - IN FONTS PAGE : SELECT TIMES NEW ROMAN UNDER FONT , REGULAR UNDER FONT STYLE , FONT SIZE AS DESIRED. UNCHECK EVERY OPTION OK CHECK WITH A PRINTOUT OR ELSE CLICK ON TIMES NEW ROMAN UNDER FONT AND CLICK ON DEFAULT, THE SYSTEM WOULD ASK YOU IF IT HAS TO BE SET AS DEFULT-SAY YES.
Sep 18, 2007 | HP DeskJet 5150 InkJet Printer
Epson FX 2170 Matrix Printer Logo
597 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
