Question about Cell Phones
LG KS360 Bluetooth problem! My phone is able to receive bluetooth data but I am unable to send out. It gives me a sending error. Does anybody know why this may be and how to solve the problem?
How to transfer music contacts videos etc from LG cookie phone into I phone
Hi, there are different ways you can send data on phone, you can use a blue tooth device
Below is a step of how you an send Data like video, music etc from LG to iphone.
How to Send Data to a Phone Via Bluetooth
Bluetooth is a type of technology found in electronics that allows you to send and receive signals and files wirelessly. Most commonly used in cell phone headsets, many people also use Bluetooth to transfer data. There is no set protocol for all devices, so instructions for use vary from one device to another. Check out the following loose guidelines for sending music from one Bluetooth phone to another, or from a Bluetooth-enabled computer to phone.
Instructions
Verify that Bluetooth is turned on or enabled in both your devices. Most cell phones will have a Bluetooth menu in their Settings or Tools. For computers, you may see a Bluetooth icon in your system tray. If unsure, check your product manual for specific instructions.
Follow the instructions to pair (connect) your two devices. If you are asked for a passkey, try entering 0000 which is usually the default for any device.
When prompted on the other device, give permission for the original device to access it.
If transferring from phone to phone
Navigate to the song you want to send and hit the button that takes you to the options menu. Choose the option to send your song; depending on the brand of phone it may say "Send" or "Move."
The next menu should ask if you want to use a text message or Bluetooth to move or send the file. Choose Bluetooth.
When prompted on the phone receiving the file, accept it.
If transferring from computer to phone
Look for an option to browse the contents of the phone. Navigate to the data file or Multimedia folder on your phone.
Navigate to the place on your computer where your Data file is kept in a separate window.
Drag the file from its original location to the correct folder on your phone.
Accept the file when prompted by your phone.
Tips & Warnings
Pairing is usually the most difficult part of the process. Make sure you read your manual on both devices if it isn't working for you. If you don't see the menu to move or send your videos, your phone manufacturer may not allow it. Check your manual or with your carrier's tech support website. This process usually applies to MP3s and not ringtones.
Hope that helped.
Good luck.
Feb 08, 2011 | Apple Cell Phones
Blackberry curve 8520 unable to receive files transfered from other Mobile device through bluetooth. But able to transfer data to other mobiles through blue tooth
My Blackberry curve 8520 can send data via bluetooth but it unable to receive data from another bluetooth enabled device. please send me solution.
Jun 17, 2010 | RIM Holster For BlackBerry Curve 8520
KS360 will not useexternal memory
in ur phone memory there is a received file folder na?delete the files......delete the phone memory...automatically ur problem ll be fixed!!!1
Oct 04, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
I need the pairing code for LG KS360
The default pin code for most devices, especially headsets, is 0000 unless it was changed.
You should be able to go into the bluetooth settings on each phone, and find the security code there, or at least change it.
Sep 15, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
LG KS360 WONT RECVIEVE THINGS BY BLUETOOTH
Heeey,
you probably have something that is stored in your phone. So just click on option, go to file and move to external.
Jul 25, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Can i save files sent through bluetooth strait to my memory card on the lg ks360
o send a file via Bluetooth:From the Start-up screen select the Main Menu icon
Go to Multi-media (Figure 1)
Select My Stuff (Figure 2)
Go the images/sounds/videos/documents and select the file you wish to send
Select the Menu icon at the bottom left of the screen
Select Send Via (Figure 3)
Then choose Bluetooth (Figure 4)
You will then be presented with a list of devices in your area. (Figure 5)
If you do not see the device you wish to send your file to ensure it’s has Bluetooth switched on and select New
Your handset with then search for all Bluetooth devices in your area (Figure 6)
Select your device and your handset will send the file (Figure 7)
The Bluetooth device you are sending your file to must accept the file (Figure 8)
To receive files via Bluetooth ensure you have Bluetooth switched on – only accept files from devices you recognise.
You will receive a message stating the file name with the option to accept or reject the file
To receive select Accept (Figure 9)
The file will then be transferred to your handset (Figure 10)
It will then be saved in your images folder
Oct 18, 2008 | LG Cell Phones
I am unable to send or receive photographs on my samsung z400 mobile phone
You can transfer or copy photos using the data cable provided when you bought the mobile. Check your bluetooth settings if you are not able send or receive data using bluetooth.
Apr 04, 2008 | Cell Phones
My Katana and Bluetooth
Some devices require you to set the device for recieving data. In the Bluetooth, menu there should be an option to "Receive File" or photo.
Mar 31, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Bluetooth
from ur bluetooth link open device history and select the blue device and delect, some of the devices.
Feb 28, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Bluetooth and infra red unable to send files to any device but can receive the files
the mobile to which u r sending file must have bluetooth on and should be in "show to all" mode
then u can transfer the files
Feb 03, 2008 | Nokia 6708 Cellular Phone
Cell Phones Logo
590 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
