Hp 9040 jams in the morning but works fine rest of the day
Thanks (copiersplusw) for the info on the hp 9040. I figured the output assy would be causing the problem. However, on the same printer the user states that every morning when the printer is started up it jams several times by the front door area. I believe its stopping right before the fuser. After a few printed jobs the printer works fine throughout the rest of the day. Any ideas?
    President:
  • 2,049 Answers
You may consider cleaning the feed rollers. If they are plastic, try isopropyl alcohol or if they are rubber, try a rubber roller cleaner similar to this http://www.simplybargains.com/80008.html
Posted on Jul 27, 2009
I put paper on my hp printer and keeps jaming up wht can i do to fix tht problem thank you get to asap thanks again
60 Second printer paper jam fix by hp technician solves feed ...
? 4:56
www.youtube.com/watch?v=BdFvyDZmiFI
Oct 25, 2011 - Uploaded by BrokenPrinter1
60 Second paper jam fix by hp technician how to solve feed ...I've been trying to figure out why my printer has been jammingfor days! Days I ...
Fixing a Paper Jam - HP Deskjet 3050 All-in-One Printer ...
? 12:07
www.youtube.com/watch?v=suiQgoH-8cM
Jul 5, 2011 - Uploaded by HP Printer Support
My hp printer was working great until yesterday when I seemed to be taking ... I was able to fix the paper jam error on my friend'shp desktjet ink ..
Oct 20, 2015 | HP Office Equipment & Supplies
What causes paper jam in hp 9040 laserjet copiers
IT all depends on the location of the paper jam. The usual causes are bad feed rollers and fuser units.
Mar 04, 2015 | HP LaserJet 9040n Printer
Hp laserjet 9040 printer shows paper jam but i can't found any paper jam
This can be caused by a few problems.
1. dust in printer: get blower an blow the printer out.
2. Paper stuck somewhere in printer: look as error and where paper jam is in and inspect that part of the printer
3. faulty sensor: replace sensor
Dec 27, 2013 | HP LaserJet 9040dn Printer
I have 2 8560 MFPs that are doing the exact same thing every morning. The printer has a false jam registering. I open the front door to clear it and then can print fine the rest of the day. Jam history...
Xerox just gave us authorized service providers notice of this problem. You will need to have a service provider come out to fix it. What city are you in? We can help you if you are in South Florida.
Mark
Computer Care, Inc.
561-477-9226
Jun 21, 2011 | Xerox Phaser 8560DN Printer
Hp 4250 laserjet is noisy and has numerous jams. page count is 137,619 maint kit has 39% left when searching event # 13.05.00 Fuser output paper late jam
Probebly the swing gear assy, this assy is driving the fuser, is defective. This is a common problem with these machines. Replacing the gear assy should solve your problem.
Feb 16, 2010 | HP LaserJet 4250n Printer
HP LJ 9040- at first fuser that was orignally
I take it your a tech or have tech ability
in my personal experience Squeeking or noticable squeeking has manily from the Output Assembly
if you can here it from the rear it is the Output assy. glad i could help
Jul 24, 2009 | Office Equipment & Supplies
Printer says there is a paper jam but there isn't
: Clear the jam from paper tray 1
  1. Remove all paper from the output tray.
  2. Turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
  5. Plug the power cord back into the product.
  6. Try printing a document.
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      1. Open the ADF, and then use both hands to gently loosen the paper.
      2. When the paper is free, gently pull it out.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP 2430 jams from optional tray 3 only.
Hi Rich,
I've had this problem too. I believe it's the post that holds the drive gears wears or becomes loose causing timing problems.. Unfortunately there's no spare parts available for the optional tray. You would have to purchase a whole optional tray.
Mar 11, 2009 | HP LaserJet 2430dtn Printer
HP DLP Parts
the part for the light engine is L1798-60003 I was unable to find a parts distrubutor for it but I think if you bug HP enough they will cave and send you one. I could not find a part number for the color wheel, sorry.
Feb 13, 2008 | HP Md5880n 58 in. HDTV
238 people viewed this question
k24674
jasbo
jasbo
