Magnavox 26MF231D/27 Unit will not power up. cord is secured and outlet is ok. Any suggestions?
    Scholar:
  • 142 Answers
You need to change capacitors 2079 and 2080 with 1000 uf, 50 volt caps. The caps are on the power board at the top as you view the unit from the rear. Also...as the other fella said....if you see any capacitors that are bulged out on top replace them with the same value micro-farads ( uf ) but a higher voltage rating. barneyluc
Posted on Sep 27, 2009
  • 585 Answers
Replace the 2200mf 16volt caps on the power supply , they are located on the power board mounted inside the shield (can) be careful of the wires running to the rear jack when removing the back. remove the screws then pop the edge loose , peek inside and disconnect wires to back, remove shield cover , then power board and flip it over to see if any capacitors are swollen replace as needed (soldered in) they must go in + and - facing as they were.
Gd Lk
E
Posted on Aug 01, 2009
NO SOUND
Check its speaker first. If it is found OK, check and replace damaged component/s in the audio output section circuit.
Feb 19, 2013 | Magnavox New Original 26MF231D Remote...
26pf4310 no picture
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Philips 26MF231D 26 in. LCD Television
Orange light 3 flashing
Check your power supply cables Your power supply cables may not be fully secured. Let's unplug and reconnect your power supply
  1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
  2. Make sure that all three connections are firmly secured.
  3. Turn your console back on.
Check the light on the power supply. If this solution worked, your power supply light will be green
Dec 29, 2010 | Microsoft Xbox 360 Console
Picture black & white menu color #26mf231d/37
I have the same problem too. Need a fix. This tv isnt that old and is not used that much. does not seem to be the cables or cable box. the menu has color to it but the channel picture is in black and white, flickers a bit, and seems to be in a very large pixle form. it this able to be fixed? Please Help.
Nov 10, 2009 | Philips Magnavox 27MS343S 27" TV
No sond no picture philips
check power in outlet , check power cords if is not cut ( check with ohmmeter), check fuse
Sep 14, 2009 | Philips Magnavox 27MS343S 27" TV
My philips magnavox 26MF231D shuts off after a couple of minutes
Replace capacitors 2079 and 2080 with 1000uf 50volt capacitors. They are at the top of the power boardas you view the unit from the rear.Barneyluc
Aug 22, 2009 | Televison & Video
Magnavox Philips 26MF231D 26 in. LCD Television wont turn on. The green power light is on but unit does not work; it won't power on or off using the power button, and screen remains black.
Most likely you have defective capacitors in the Power Supply. It is not an expensive repair but something that needs to be done by a svc. co., if your not familiar with Switch Mode Power Supplies (SMPS). I hope this helps and Thank You for using FixYa.. Let me know....
Mar 10, 2009 | Philips 26MF231D 26 in. LCD Television
Power button stopped working and no remote
you can get a programable remote to get around that.
Feb 12, 2009 | Philips Magnavox 27MS343S 27" TV
32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Jul 04, 2008 | Philips 26MF231D 26 in. LCD Television
Philips magnavox won't turn off and stay in demontration mode
Hold both volume buttons at the same time for 6-10 seconds and that will reverse it. This has been proven to work!!!! YEAH
Mar 03, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
376 people viewed this question
Top Televison & Video Experts
Electro Med Services...
