I NEED TO PROGRAM A HONEYWELL TH8320U 1008 THERMOSTAT, AND CANNOT FIND THE MANUAL. IS THERE SOMEWHERE I CAN DOWNLOAD THE MANUAL?
  • 3,289 Answers
Direct link from Honeywell:
http://www.forwardthinking.honeywell.com/related_links/thermostats/visionpro_8000/install/69_1894ef.pdf
Posted on Aug 12, 2009
    Scholar:
  • 174 Answers
Http://homeappliance.manualsonline.com/ex/thread/view/idThread/2244962
Here u go.
thanks.
Posted on Jul 27, 2009
Is the th8320u 1008 thermostat PROGRAMMABLE?
Yes the Honeywell TH8320U1008 touchscreen thermostat is programmable. See https://customer.honeywell.com/en-US/pages/product.aspx?cat=HonECC+Catalog&pid=TH8320u1008/U for the operator's manual. Click on the Literature tab and scroll down to the Owners Manual section. If your thermostat isn't working, make sure that it is set for heating or cooling, as needed. Then check the batteries, the wiring and the HVAC system. (The thermostat has a default set of heating/cooling periods.)
It's not uncommon for one of the wires going to the thermostat to break. Find the undamaged section of that wire and secure it under the appropriate contact spot. Make sure all of the wires are positioned at the correct contacts.
I hope this helps.
May 18, 2018 | Heating & Cooling
My thermostat when prgrammed and set on "auto" mode kicks on heat when temp drops below set temperature. The problem is that after warming up to that temperature...it does not shut the fan off. ...
I have a honeywell TH8320U thermostat and American standard Air handler with heating unit put in. THE thermostat works fine with the ac and follows the programs I have set. However the heat is a different story. The thermo clicks on to follow program but the unit does not run. (auto settings) If I place the thermo in heat and turn it to on I get heat?
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
How do I program my honeywell chronotherm IV Plus thermostat? can I download a manual
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 28, 2010 | Honeywell Electronic Programmable...
Honeywell TH8320u Vision Pro 8000 Digital keeps calling for heat
If the thermostat is not over shooting the temperature than don't worry about it.
These thermostats are very sensitive and will turn the heat back on even before the degrees drop on the display. Often they will shut down before the display changes also. You can change the sensitivity of the thermpstat if you read the directions and change the cycles per hour to a less number. There is an installers program in there that you need to push a combiunation of buttons to get too. The instructions tell you how to do that also.
Hopefully you did not throw away the instruction manual for your t-stat.. :-)
Heatman101
Dec 28, 2009 | Honeywell Programmable Thermostat Heater
How do I program my honeywell basic thermostat?
Go to
myhome.honeywell.com
and search for a manual for your model number thermostat on the right hand side of the page.
Oct 10, 2009 | Honeywell Programmable Thermostat Heater
Wiring Trane/Honeywell TH8320U
use the outside designations for heat pump, and inside for standard, I would assume a heat pump since you have more than five wires attached to it now. Use the colors of the wire to match to the designations, use tan for y2, black for w2 rc and rh should already have a factory jumper. I would have to trace out the "U" and see where it terminates, I have not seen a bare wire on a stat in 27 years of doing this. before powering, verify the tan and black at the indoor unit circuit board and see if they are landed on the terminals designated at the stat. hope this helps
Jul 27, 2009 | Heating & Cooling
I have a vison pro th8320u cant get aux heat to work
http://customer.honeywell.com/techlit/pdf/69-0000s/69-1871.pdf take and click on this link, then go to the installers menu and on option 0170 that is where you have to program the thermoistat to have aux heat. good luck
Jan 10, 2009 | Honeywell Electronic Programmable...
I'm trying to hook up a honeywell touchscreen thermostat and need to know what wires go where.
i have a vison pro th8320u and i cant get aux heat to operate also aux heat on will not come up on the touch screen.
Jan 04, 2009 | Honeywell Electronic Programmable...
I can't program my thermstat
go to www.honeywell.com. There you will find a search tab. Type in the exact model number of your thermostat. You will be able to download the installation/owners manual.
Nov 29, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
204 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
