Check the line cable. Try inserting that line to another telephone
unit. And if there's still no dial tone the problem is on the line
itself. You should call your line provider.
But if the line is
ok, check the LIU connectors if it is inserted correctly. It the
connectors are ok, then the possible problem is on the tel. line
circuit on its mainboard.
Philips has sold its Fax business to Sagem. You can find the manual in English, French, Italian and Dtuch here: http://support.sagem-communications.com/site/modele_fax.php?page=livret&prd=FAXJET325&pays=uk
sounds like your communication board is out or your phone line is not working when you unplug your line and put a phone on it can you get a dial tone? then your fax machine is probably broke
call the number manually . and does it answer with a warble immediately or does the phone ring a lot and then answer. your timeout may be set too short on the sending fax setup.
does the print head move freely back and forth on the carriage?
If it dioesn't then that will cause the printer to error out and may give you a error 3.
Not sure but try a little oil on the carriage and move the assy back & forth a couple of times then clean the carriage off with a paper towle and try turning it on. does it still error out?
