2004 c230 A/c left side warm Right side ok
    President:
  • 1,922 Answers
Low on freon or a plugged expansion/orfice tube,whichever they use,which will cause a "super-Heat" condition
Posted on Jul 27, 2009
Mass air flow sensor where is it located in the engine of a c230 mercedes 2004.
mass air flow is right behind the air filter box if it's a c230 kompressor.
Oct 04, 2010 | 2004 Mercedes-Benz C-Class
2004 crf 450 r atifreeze in the oil and put new water pump and all that in it and they say it needs head gasket but if that dont work does that mean the blocks cracked
You may have put the seals in backwards. They must go in a specific direction. If that is ok, is the water on the right side oil, or left side oil? Right side you have a seal problem, Left side you have a head gasket. The cylinder wont crack unless destroyed. Replace head gasket and the bad oil on bad side. Chaz Moto DC
Feb 25, 2010 | 2004 Honda CRF 450 R
2004 navigator left side is down left front sensor not moving would that cause left rear not to raise up. RIGHT SIDE OK
yes, why is sensor not moving , did it unhook ,if so hook it back up, also the air back might have a hole, start engine and listen for an air leak at left rear, if hissing noise is heard then spary bag to see if leak is on bag if so replace suspention bag hope this helps good luck,
Oct 17, 2009 | 2004 Lincoln Navigator
Door Lock Malfunctioning
power door lock solenoid may need replacement
Jul 04, 2009 | 2007 Mercedes-Benz C230 Sedan
How to change air filters on 2007 Mercedes C230 Sport
I have '05, both should be similar:
1.Cabin air filter is located above battery on right side against firewall.
Release three latches, remove filter housing, slide old filter out (housing is flexible), insert new
one, reinstall housing.
2.Engine air filter is on the left side of the block (follow intake hose). Cover is retained with six screws
(six point star shape,I belive called Torox, bit/scredriver size 25). Loosen screws (don' t pull all the
way out of the cover) lift cover , and remove old filter. Insert new one, reinstall cover. DO NOT
OVERTORQUE SCREWS! Screw holes in plastic filter housing strip very easily.
Note: Intake hose is very flimsy, one on my car came apart and had to be replaced.
Mar 25, 2009 | 2007 Mercedes-Benz C230 Sedan
2004 Mercedes C230 Kompressor coupe
try the door module. get the one from the driver side and try it on the passenger side . most common problem on mercedes
Jul 14, 2008 | 2007 Mercedes-Benz C230 Sedan
Open Questions:
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
