Baseline tv child lock on Remote broken - have bought universal but doesn't have a code What do I do
  • 269 Answers
Can you give me a specific brand or model of your unit.
Posted on Aug 01, 2009
Nikai japan ntv2190stf no working remote control
To open its child lock, you might have its original remote control. Try these methods. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 01, 2013 | Philips Magnavox 27MS343S 27" TV
How to get child lock off of my daughters TV I forgot the code help!
The procedure to unlock the child lock to TVs will differ brand to brand. The general procedure to most TVs are:
Check this. If you wish to get more details about unlock a TV, check the site linked here. Pull up older posts. Unlock procedure to many popular brand TVs are given in detail.
google.com/+GopakumarGopalan
Nov 25, 2013 | Televison & Video
My Palsonic LCD TFTV81PBHDT remote is broken and buttons on side panel do not seem to work. How can I switch tv on to tune to universal remote? Do the side buttons have some sort of child lock function...
you can program most universal remotes to work the tv and menu the child lock is activated on the tv and the buttons will not work only power button will work as long as it has not been set to not work when made. some are set this way. but a remote with the right code set will turn on the tv.
Sep 20, 2013 | Televison & Video
The child lock is on my tv hitachi older model. i have no remote and the tv is turned off.. how do i get it back on to remove the lock???
The child lock on a TV can be a wonderful thing. A parent sometimes cannot be present for the duration of a kids' show, so the child lock ensures they can't watch programs that are off limits. The lock can, however, cause unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Follow a few easy steps you'll be back to watching regular TV in no time.
Instructions
Oct 03, 2012 | Televison & Video
Child lock on no remote
Apr 20, 2012 | Philips Magnavox 27MS343S 27" TV
How can i turn on my tv which has child lock on with no remote?????
If you purchase a universal remote that can work with the philips magnavox, test and go through each codes until the tv comes on in which case you can navigate to the MENU, SET, and then CHILD LOCK to turn the feature off. With the tv plugged in, it can still receive signals from the universal remote and once you get the right code, it should be able to turn on.
You can even return the remote afterwards if you really dont want it. =]
Mar 12, 2011 | Philips Magnavox 27MS343S 27" TV
I have the child lock on and the remote control is broken. How can I turn the tv on without the remote control
The power button on the TV doesn't work because of the child lock?
I went over the copy of your manual for your TV. It must be the child lock timer problem.
I would try leaving the TV unplugged for 30 mins and see if that reset the TV and releases the lock.
If it doesn't work, the remote needs to be replaced. A universal remotes aren't really universal when you need to use special buttons. The remote made for the TV is the best.
If your TV is the model 47PFL7403D, here's the cheapest place to buy a replacement.
http://www.philips.newremotecontrol.com/catalog_item.php?catnum=313922852812
May 12, 2009 | Philips 47PFL7403D 47 in. LCD TV
Cant get tv on
HELLO. YES IT'S TRUE ALL TV MUST BE ON TO PROGRAM THEM.!!! AND ALL MOST SET THAT HAVE A CHILD LOCK ON THEM .!!! YOU MUST HAVE THE REMOTE FOR THAT SET.!!! TO MAKE IT BRING UP THE MENU DISPLAY.!!! TO TURN ON & OFF.!!! THE CHILD LOCK..!!! THERE ARE SOME UNIVERSAL REMOTE'S THAT WILL FOR MOST .!!! TRY A (UNVERSAL CONTROL ONE) REMOTE .!!! THEY WORK WITH MOST OF THE RCA SET MADE.!!! HOPE THIS HELP'S YOU .!!! "GOOD LUCK"
Apr 30, 2008 | RCA 20F511T TV
Phillips 28PW6006/05-Locked
First you need to get your remote working, without it you cannot unlock the tv. If the romote is not phisically broken (or smashed) make sure the battery contacts are clean and install new batteries.
Once you get the remote working (hopefully) Enter the MENU and select 'Features'. Set the Child Lock to OFF. If you cannot get the remote to work try a universal remote, setting it up with the codes for your tv provided in the setup manual for the universal remote.
Mar 17, 2008 | Televison & Video
27" MAGNAVOX W/ CHILD LOCK ON- NO REMOTE!
On those particular Magnavox TV's you have to use the original type of remote to power it back on then un-lock the parental lock. It is a bummer that nothing else will work. Here is a link to purchase a replacement remote.. http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod
Feb 06, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
