Question about Canon DR-9080C Path-Through Scanner
Canon DR7580 only pulls one page then stops. Cleaned sensor to no avail.
  • 490 Answers
First select count only mode and put a bunch, check if the roller/scanner is picking up and counting okay. If this is done, then you must check your software settings. May be your command is to scan only one page. If the scanner is not counting properly, then clean the rollers with a damp cloth. The ****** (bottom one near tray) roller must be cleaned ideally when power is off.
S. Mohan, Chennai, India
Posted on Jul 27, 2009
How to replace sensor in DR7580?
Which sensor do you need to replace? These machines have several sensors throught the machine that assist with lifting the tray, watching for staples, and even double feed detection.
Feb 19, 2014 | Canon DR-7580
Scaner doesn't work. It alway show the error message: "No page was found in the feeder. (-4401).
Pls try page counting in the local mode, If the tray lifts, then you know the sensor is ok. else, wipe clean the two black spots just under the rollers and try. Normally these sensors dont fail.
Dec 24, 2010 | Canon DR7580 PassThrough Scanner
Canon scanner dr7580 not working. E32
As per Service manual , E32 is "Wrong installation of main CPU PCB (The CPU PCB for a DR-9080C has been installed in a DR-6080 or vice versa.)"
Oct 06, 2010 | Canon DR-7580
Canon DR7580 error code e31
E31 refers to abnormalities in mechanical Counter. Check if it is installed properly. The scanner can work without this also.
Sep 24, 2010 | Canon DR-7580
I have a Canon Scanner DR7580 and the wheels are hesitating upon feeding of the document.
The rollers slip if a) the document is slippery or dirty, b) if they are unclean after usage or c) if there is hardware problem.
Try scanning a set of clean sheets, clean the rollers with a damp cloth thoroughly (no solvents pls). Get QUMA tool and check if the rollers are working independently.
S. Mohan
Mar 15, 2010 | Canon DR-7580
Paper Jams - Multiple Pages Pulled - New Rollers Installed
If you have de-stapled papers, the papers may still be held together where it was stapled. Fan the papers before feeding, Check if the '******' roller (the light brown bottom roller) is clean.
S. Mohan
Feb 16, 2010 | Canon DR-7580
Chevy impala pulls up to the stop sign & stops running,started right back up & drove home died again as I entered my driveway. A tune up & servicing recently completed. Any suggetions?
throttle position sensor was probbally cleaned improperly(it is ill advised to clean the intake sensors, but to no avail some mechanis think it can be done) you will now have to replace the throttle position sensor, let me know if this helps.
Dec 19, 2009 | 2003 Chevrolet Impala
Canon Pixma MX310: misfeeds
Hi Paper misfeeds are normally caused by something obstructing the paper path. Look really carefully both above and below the path that the paper takes through the printer. The jammed paper itself can give you a clue about which side the obstruction is on, there wiil often be some sign, such as a bent corner on the page etc. Also check the sliding guides that keep the paper straight, they should be slid in until they are a snug fit with the paper, but not so tight that they stop it from feeding
Jun 21, 2009 | Canon PIXMA MX310 All-In-One Printer
Scanner pulls page in to just past the bottom sensor lever
Please ensure that the rollers are clean and within its life span. (Rollers wear out and need to changed after 250,000 pages or as recommended by mfr). FAn the pages before scanning, Ensure the edge is trim with no folds or bends. The griniding noise is because the scanner has picked up more than one page.
S. Mohan. India
May 29, 2009 | Canon DR 3080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
339 people viewed this question
old marine
old marine
