Question about Braun Tassimo Espresso Machine/Coffee Maker
Machine won't go to auto
It seems to default to Manual, and I do not know how to get it back to automatic. Random and frustrating!
Try cleaning the part on the machine that reads the bar code on your t-disc. This was happening to me. . . I cleaned that piece, and it started working properly again.
Posted on Aug 03, 2009
DO YOU HAVE a manual for a woods e227659 TM-068-2 timer?
Woods TM-068-2
Indoor 7-Day Astronomic Timer
125V ac / 60Hz 15A / 1875W general purpose
8A / 1000W tungsten 500VA electronic ballast
15A / 1875W resistive 120V ac / 60Hz / 8,3A ballast
FEATURES:
• Up to 7 different programmable ON/OFF cycles, cycles repeat weekly.
• Programming fl8xibilify: u8hts fun on/off automatically at sunset/sunrise,
or at any programmed times you choose.
• ln Sunrise/Sunset programming mode, timer will automatically adjust the
programmed ON/OFF cycles to match current sunrise/sunset times.
• Timer automatically adjusts to daylight savings time
WARNING: TIMER IS INTENDED FOR INDOOR USE ONLY!
BEFORE YOU BEGIN PROGRAMMING THE TIMER:
This timer has in internal battery backup to save all programming.
  1. Plug the timer into wall outlet for 30 minutes to charge internal battery.
  2. After 30 minutes, unplug timer and press the RESET button with the tip of a toothpick or similar object to clear the memory.
TO SET THE CLOCK:
  1. Press SET. PRESS +/AUTO or -/RDM to set the current year.
  2. Press SET. PRESS +/AUTO or -/RDM to set the current month from 01 to 12.
  3. Press SET. PRESS +/AUTO or -/RDM to set the current date.
  4. Press SET. Daylight savings mode (DST) will appear on the bottom of the display. PRESS +/AUTO or -/RDM to set mode to either DST AUTO or DST OFF.
  5. Press SET. PRESS +/AUTO or -/RDM to set the current hour. To change between AM and PM, press +/AUTO or -/RDM 12 timers.
  6. Press SET. PRESS +/AUTO or -/RDM to set the current minute from 00 to 59.
  7. Press SET. PRESS +/AUTO or -/RDM to set the Astronomic function to your zone - North (nor), Central (cen), or South (sou).
  8. Press SET to view the sunrise time. To adjust sunrise time press +/AUTO or -/RDM. To go back to the default sunrise timer press ON/OFF.
  9. Press SET to view the sunset time. To adjust the sunset time press +/AUTO or -/RDM. To go back to the default sunrise timer press ON/OFF.
  10. Press and hold SET for 5 seconds to exit clock setting mode.
Note: The timer allows a maximum of 7 programmable ON/OFF cycles.
To program the first ON/OFF cycle: Press SET repeatedly to scroll through setting the clock mode.
  1. Press SET to display ON 1 setting.
  2. Press +/AUTO or -/RDM to select day or group of days you want for cycle 1. Scroll to select either every day, any individual day, weekdays only, or weekends only.
  3. Press SET. Set ON hour by pressing +/AUTO or -/RDM to scroll through and choose hour AM or PM, or Sunrise/Sunset icon for first ON setting. Note: To select Sunset or Sunrise for the ON time, you must scroll through all the AM and PM hours first. If you select Sunrise/Sunset as the programmed ON time, press SET to continue programming OFF setting.
  4. Press SET. Press +/AUTO or -/RDM to set ON minute from 00 to 59.
  5. Press SET to display OFF 1 setting.
Repeat steps 2-4 to program desired OFF time.
To program additional ON/OFF cycles: Repeat steps to create additional ON/OFF cycles (ON 2-OFF 2, ON 3-OFF 3, etc.) up to a maximum of 7 different ON/OFF cycles.
Press and hold SET for 5 seconds to exit programming mode. Note: During programming, if no button is pushed for 30 seconds, the timer will automatically return to standby mode. Press ON/OFF to cancel any setting.
Sun tracking technology: Timer adjusts automatically to changing sunrise and sunset times in sunrise/sunset mode is chosen for any programmed ON or OFF time. For example, if you program a cycle to turn ON at sunset and OFF at 10:00 pm, the timer will automatically adjust ON (sunset) time as sunset time changes throughout the year (and will always turn off at 10:00 pm as programmed).
IMPORTANT! REVIEW PROGRAMMED ON/OFF CYCLES: Press SET to advance through all programmed ON and OFF settings. Make sure there are no overlapping ON or OFF times. Stop at any programmed setting you want to change.
To operate timer: Press +/AUTO until AUTO appears in display. Timer must be in AUTO mode for programmed settings to operate. Plug appliance (such as lamp) into timer and plug timer into wall receptacle.
IMPORTANT: Appliance must be turned ON or be in the ON position before plugging it into timer.
SECURITY (RANDOM) MODE: To operate a plugged-in appliance (such as a lamp) in a random pattern while you are away, to simulate actual use: press -/RDM until RDM appears in display. In Random mode, plugged-in appliance will turn on and off at random, approx. +/- 30 minutes from the programmed settings.
To cancel Random mode, press ON/OFF until RND disappears from display. Timer will now function using your previously programmed settings.
DAYLIGHT SAVINGS (DST) MODE: If timer is in DST AUTO mode, clock time (and sunrise and sunset time) will automatically increase 1 hour on the second Sunday in March at 02:00 am and decrease 1 hour on the first Sunday in November at 02:00 am.
TO OVERRIDE THE TIMER: Press ON/OFF until desired mode is displayed:
ON: Programmed settings will be overridden; the plugged-in appliance will remain on
OFF: Programmed settings will be overridden; the plugged-in appliance will remain off
AUTO ON: Turns plugged-in appliance on immediately until the next programmed OFF time. Press ON/OFF until ON displays on the screen, then press +/AUTO and AUTO will display on the screen.
AUTO OFF: Turns plugged-in appliance off immediately until the next programmed ON time. Press ON/OFF until OFF displays on the screen, then press +/AUTO and AUTO will display on the screen.
RDM ON (Random ON): Turns plugged-in appliance on immediately until the next random off. Press ON/OFF until ON displays on the screen, then press -/RDM and RDM will display on the screen.
RDM OFF (Random OFF): Turns plugged-in appliance off immediately until the next random on time. On/Off times will vary +/- 30 minutes from the programmed settings. Press ON/OFF until OFF displays on the screen, then press -/RDM and RDM will display on the screen.
Consumer Support (800) 561-4321
www.colemancable.com
Dec 12, 2017 | Woods Hardware & Accessories
What is the default blue tooth code to sync with auto ?
Normally 0000 or 1234 are the default, but your auto's owner manual should have it, many manuals are online now if you don't have it. I think my car display actually flashed a random code for me to use.
Jan 04, 2016 | Apple iPhone 5
Samsung D73 camera
Does this also happen when you switch the camera to automatic?
Sometimes without knowing you can put the camera in manual, and have ictures much to light or much to dark. If you are not familiar with manual shooting, please put the camera back to auto (green camera loge on the dial)
Dec 31, 2013 | Cameras
Pfaff 2170 will not make consistently sized buttonholes
Go to the following site regarding timing your machine. Are you placing a button in the buttonhole foot so the machine "knows" how long to make the buttonhole? If you have a button stop lever to the left of your needle bar, are you pulling it down and putting it in FRONT of the button stop so it can complete the rotation?
Try www.fixsewingmachine.com
Try http://www.manualowl.com
Apr 13, 2012 | PfaFF Sewing Machines
How to set machine to receive incoming fax?
Quoted from the manual: The HP all-in-one will not automatically answer calls. You must receive all faxes manually by pressing Start Fax Black or Start Fax Color. For information on receiving faxes manually, see Receive a fax manually. You might use this setting if the majority of calls on this phone line are voice calls and you rarely receive faxes.
This page has more information: http://www.fixya.com/support/p378554-hp_officejet_6210_all_in_one_inkjet/manual-3600/page-86
May 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Setup
It should automatically default to AUTO RECEIVE. Plug the phone cord into the LINE port on the machine.
Dec 23, 2008 | Brother IntelliFAX 1840C Plain Paper...
UX-B800SE Fax
First it would seem as though the default setting may have all been changed. The NO SERVICE message is given because the machine menu setup is not able to comply with present hardware configuration. Such as the menu setup calling for the incoming fax to be forwarded to an email only you have not connected the machine to an internet router.
The most likely thing to do that will fix the fax not being automatically answered is this.
Check this menu setting. Press the <RESOLUTION RECEPTION MODE> Button (with no document in feeder) until AUTO appears in the display to set auto recieve faxes.
This will auto answer a fax after the set number of rings (different menue option). As someone may have changed this it can be from 2 to 5 rings. Note there is also a pseudo ring tone which can also be set although this will only ring on the machine itself.
This is in case the machine auto answers then finds the incming call is not a fax and so need to altert you to take the call.
Now this is a very complex machine so CAUTION when using in a doctors surgury. It is capable of BROADCASTING all the faxes to any other fax machine or email adresses either by design or the office 'meddler'.
You should set the SECURITY password option and keep a copy of this safe to avoid unauthorised access or changes which could then forward your faxes to unknown destinations.
You need to take a week off to read the manual as it is not easy to plough through.
Here is a link to the MANUAL also what is laughing called a 'setup guide'. My advice is to first disconnect the phone line, then go through each menu setting the DEFAULT value. Then try it, then change the setting to suit you. This is no ordinary fax machine.
http://www.manualsmania.com/model.php?model=6a539582aaef41608ed1fb531d872ebc5098af39
You will of course want to selct the English language GB version of those listed. Then enter the anti-spam code which will download the PDF documents.
Any problem with this such as the link disapearing then i will redo it.
Feb 08, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Stuck in a Mode
http://www.scantracker.com/KansasCityrepairs.html
These guys are repairers so they may have extra copies.
IBM's Typewriter's site also has manual for sale for less than $20.
The typewriter seems to have a bad ribbon cartridge or a bad typing wheel. Take each one out and try to see if it will type normal. If one does, then you know to replace it.
Zabrina
Jan 08, 2008 | Office Equipment & Supplies
Braun Tassimo Espresso Machine/Coffee Maker Logo
384 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
ellipse0904
Level 1 Expert
Jim Thurston
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
