Question about AKG Perception 200 Microphone
My AKG Perception 200 Cut the signal suddenly
Suddenly it started doig this thing when it's working the level go down suddenly.. i tried diffrent cables with it and diffrent PA and it's not getting any better
  • e_felber90
    e_felber90 May 13, 2012
    i have the same problem. have you found a solutuion? thanks
    Problem Solver:
  • 12 Answers
Sounds like a loose connection. Try duct taping the microphone cable in place where it enters the microphone.
Posted on Jul 29, 2009
Akg perception 220 professional microphone
Try building a little mike-preamp with an opamp to boost the signal.
Enough schematics on internet.
Or walk into an electronics shop for a ready to build package.
These are the things I can suggest; I don't know your audiobox.
Perhaps there is internally a pot-meter to adjust the gain of your mike; that would be the easiest solution.
Mar 06, 2014 | PreSonus AudioBox 22VSL 2x2 USB Interface
My akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
Jan 11, 2010 | AKG Perception 200 Microphone
Creates excessive noise with no signal
Could you swap with a different mic so you could be sure if the line/cable are allright or confirm that the mic is defective... Also when repairing a mic, 90% of problems come from the connector welds. Use a small flat glasses screwdriver and have a look at the weld of the xlr connector from the inside...
Oct 07, 2009 | AKG Perception 200 Microphone
AKG Perception 200 Mic stopped working. I use it
The simple thing to check would be to see if your 48V phantom power switch on your mixer is turned on. Sometimes there is an individual button to turn it on and off for each channel strip. Good Luck
Oct 06, 2009 | AKG Perception 200 Microphone
Microphone cuts out
If you tried other cords and other PAs the problem might be in the jack where the cord plugs into the mike. service@akg.com might also be able to give you more info.
May 18, 2009 | AKG Perception 200 Microphone
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
AKG Perception 100 not working, at all
The problem is that your amp probably doesn't have phantom power. This mic requires phantom power to be supplied to it via the XLR connector. Most mixers and mic pres have that feature, but most guitar amps do not, I believe. Hope that helps...
Jun 08, 2007 | AKG Perception 100 Microphone
AKG Perception 200 Microphone Logo
398 people viewed this question
Top AKG Audio Players & Recorders Experts
Vito Vacirca Jr.
Ben Armstrong
Edward Carrington...
Level 1 Expert
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
