Question about Rockford Fosgate p-450.4 Car Audio Amplifier
Amp blowing fuses
I have a punch p450.4 amp and I was driving and the my music stopped. I saw that the protct light was on and when I restarted the car the power light was on but just cracky sound. When turned up, the amp goes into protect mode. I removed the stereo a pioneer avic d3 everything was good. I unhooked one rca, it touched nothing, sound came back, and then the amp blew the fuses. now, with the correct fuses replaced everytime the amp goes to power up it blows both fuses. I am thinking it has an internal short?
  • 631 Answers
The amplifier probably has shorted output transistors.
Disconnect the speakers and RCA cables. Replace the fuses with two 10 amp fuses or a single 20 amp fuse. If the amp blows the fuse when it powers up, the outputs are almost certainly the problem. Don't try it with the two 30 amp fuses. The smaller fuses will provide more protection for the power supply. If the amp powers up with the smaller fuses and they don't blow, check the speakers and the wiring (for shorts to ground or shorts between wires).
Posted on Nov 22, 2007
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ... > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
How do I replace the linear ball bearing on a c8fb2 Hitachi miter saw
Its not too difficult:
1) There are 2 retainer pins located on the rear slide support (#4 on breakdown) - carefully drive these out with a punch - be careful to support the bracket so you don't break it.
2) remove the rear support and slide the saw head and arms out of the bearing.
3) Remove the 2 covers (front and rear) over the bearing
4) loosen the allen head set screw on the housing that holds the bearing in place
5) using a large socket and a plastic hammer - gently tap out the old bearing.
Reverse process to replace.
Do not use grease or oil on the bearing or slides - use a pure, clear silicone spray that dries completely - grease & oil attract & hold dirt and debris and will cause bearing failure.
Hitachi C8FB2 8 1 2 Twin Rail Sliding Compound Miter Saw Parts
Feb 14, 2015 | Hitachi Power Tools 8-1/2" SLIDE COMPOUND...
Rockford Fosgate P3002 stopped working
push down and up on your subs and see if they make a starching noise, if they do then they are blown. take a test light to the amp, on the power and the remote and see if it lights up. if it does then turn the amp down and with a small speaker plug it in to the speaker outs on the amp and see if it plays if not then your amp is bad.
Nov 26, 2013 | Rockford Fosgate Punch P3002 Car Audio...
2005 colorado shuts off unexpectedly when ac is on..why?
Could be because the alternator is not charging properly (failing), and/or because the battery is weak.
Jan 11, 2018 | 2005 Chevrolet Colorado
Were is the fuse located on the punch 300s?
I just read all the information about this amp on crutchfield and never saw anything about a built in fuse or external fuse. I don't think it has one.
May 22, 2011 | Rockford Fosgate Punch 300S Car Audio...
My 02' mdx won't come out of park, keep blowing a 20 amp fuse. This fuse controls the Cruise, break lights, memory seat, horn and linkage. I have to manually delink. I have unhooked the comand...
Here is an idea, when do you blow the fuse key on, key on engine running, key on engine running hitting the break pedal? Try and get the key on without blowing fuse if possible, then one at a time try those circuit loads ie: horn, brake pedal and so on, if you isolate which load is pulling to many amps(blowing fuse) unplug that load itself, then restart testing, see if fuse stays ok. You can also substitue the fuse with a circuit breaker and unplug each load until click(of breaker) stops.
May 17, 2011 | 2003 Acura MDX
Most amps have a remote on terminal, which takes a small current wire to "turn on" the amp, and when you stop current to that terminal, it turns off the amp. It sounds like this current is still live when you turn the car off, so your amp doesn't know to turn off.
With the car off, test the lead at the remote on terminal (usually blue wire, as I do it) with a dc meter or test probe. If it reads +12v, it shouldn't. Find a new "remote on" power lead. This is generally provided by the "power antenna on" lead out of the deck. Run a wire to the amp from the power antenna on lead, and retest.
I'll bet on success after this.
May 05, 2011 | Rockford Fosgate Punch 200a4 Car Audio...
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
While cutting , i experienced a bind. Before the saw stopped I shut it off. Left overnight, now will not restart. I have pushed the thermal reset button, however it does not seem to engage. I have checked...
Is this a direct drive or belt drive saw? If belt drive, you can remove the belt and try spinning the motor by hand then turn it on. Sometimes they can get stopped in a dead spot. Do not get your hands/fingers in the way when turning it on. You may need all of them someday.
Aug 08, 2010 | Hitachi C10FL 10" Stationary Table Saw...
Rockford Fosgate p-450.4 Car Audio Amplifier Logo
534 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
