Question about Sony Xplod 500W Bridgeable Multichannel Amplifier
Protection lite and over current lite stay on
I have a sony explod 2 channel amp. when i turn the amp on the protection lite and the over current lite stay and the thermal lite stay on.
any idea what could be the problem. also wen i measure the voltage of the first channel i get the correct voltage. but there is no voltge across the caps after the coil (second channel).... please help its asif the current stops at the coil. coid the coil be a the problem.
  • 30 Answers
Sounds like a problem with the coils. Coils are known to short-out during periods of high-use. This happens when the insulation between wires break down and allow for a path of lower resistance for the current to travel. If this is the problem, you'll have to replace the coils in the amp which is a weekend job, but completely do-able. Hope this helps
Posted on Jul 27, 2009
Red power/protector light
The amplifier has gone into protect mode and will stay in that mode until the cause is corrected.
Nov 17, 2013 | Sony Xplod 800W Class AB Bridgeable...
Why is my sony explod 444 amp going in to protect modewith in 2 minuts
it needs cooling plus you need to turn down the outputs. you trying to push it to hard,in this case upgrade to bigger amp.
Dec 20, 2012 | Car Audio & Video
One channel thermal overload stays lit and no output from that channel. even after unit sits overnight, thermal light on immediately,unit not hot. Looking for schematic?
Red light is on if:
- thermal protection, overheated amp, bad thermo sensor
- DC at speaker terminals
- high current at output transistors
Also could be a protection circuit malfunction.
In any case you need new channel module or send your module or whole amp for repair here.
Thanks,
Paul
Jul 12, 2011 | Adcom GFA-7607 7-Channel Amplifier
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
I cant run my 2 sony explode 12's brigde of my amp
either don't bridge it or you will have to turn the amp down.
Jan 30, 2009 | Sony XM-1252GTR Car Audio Amplifier
Hi when i turn on my servo 170 my protection lite stays on
One of the channels in the amp is bad. That channel will need tobe replaced. You may need to take it to a repair shop.
Nov 12, 2008 | Samson Servo 170 Amplifier
760 sony explode amp in protection mode
I have a Sony X-Plod amp 760w 2/1 channel xm-1902gx. Everything is connected properly and the amp contains 4 lights (power,over current and two others). Power lights up like it's supposed but the over current lights up as well. I am unable to get any sound from it. Can you help me before I trash the amp.
Nov 01, 2008 | Audio Players & Recorders
Kenwood kac 859 amp
hi, note that if you are not using the proper gauge b+ and gnd cable with this amp then the current available at the amp wont be sufficint to keep amp on. also try using this amp while vehicle is idling. if this doesnt work then disconnect all spks from amp and check if red lite stops flashing. if it doesnt stop flashing then amp has internal fault. if lite stays on brite then proceed to check each spk load impedance, then reconnect each spk individually. the minute red lite starts flashing it will give you a clue that the channel or spk load is faulty. cheers
Jul 27, 2007 | Kenwood KAC-859 Car Audio Amplifier
Sony Xplod 500W Bridgeable Multichannel Amplifier Logo
109 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
