Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
No more suction on hose attachment
The problem started slowly- it appeared to be a leak at the gasket? It is NOT a clog problem. The vacuum is barely one year old.
  • jmfrazer Aug 01, 2009
    Hey Andrew,
    Thanks for your response. The foam filter has been cleaned and I removed the u shaped tubing and checked. I did not find a clog in the u shaped tubing, but doing that seemed to make the hose attachmen work for a few minutes then the problem resumed.
    Any other ideas? Thanks!
  • 120 Answers
Have you cleaned the foam filter? there should also be a u shaped piece of tubing that connects the attachments to the rest of the machine, sometimes it gets clogged ( quite often, i repair on average 3 dysons a week ) also people tend to loose the tube as well.
Posted on Jul 27, 2009
I put a new bag in my electrolux 2100 and it seems like it has half of the suction. What seems to be the problem. Does it need a new upper motor gasket?
Take the hose off, turn the vacuum on and see if there is good suction at the vacuum where you attach the hose. If there is good suction at the vacuum there is either a clog in the hose or if it is an old hose the liner inside the hose may be collapsing when you turn the vacuum on. If that is the case you will need to purchase a new hose. I have hoses for sale on my website and on ebay.
Mar 06, 2014 | Vacuums
No suction from canister on electrolux guardian model c154e. green light on switch is on
Have you remove the hose and checked the suction at the intake of the vacuum? If the motor is running there will be suction.
If there's suction here, attach the hose to the vacuum, turn it on, and check the end of the hose for suction. If there is none or very little, there's a clog or bad leak in the hose. The easiest way to check for a clog is to drop a coin in one end, lift that end up allowing the coin to drop through to the other end and out. If it drops through, the hose is clear. If not, the easiest way to clear it is to plug the hose in to the exhaust port of the vacuum, place the other end into a large garbage bag or point it outside, and turn on the vacuum. This will usually clear a blockage.
Leaks that are severe enough to result in no suction will be readily apparent as tears, cracks, or cuts in the hose. A crushed hose will also result in the loss of suction.
If suction is fine at the end of the hose, do a visual check of the wands. It's unusual for them to be blocked, but not impossible.
Check the power nozzle above and behind the brush and where it attaches to the wand. The elbow can catch long objects resulting in a blockage.
If there don't appear to be any problems with the above mentioned items, you need to take the vacuum, with attachments, to a repair shop to have it checked. It may need a new motor, but that would be due to worn out or broken fans, and that is unlikely with Electrolux vacuum motors years older than that.
Dec 01, 2013 | Electrolux Guardian Bagged Canister Vacuum
Poor suction in system - I have used shop vac to suction all three receptacles. Have checked bag and cleaned everything. Still poor suction. I have one receptacle in garage that works perfectly. Must...
Have you checked the hose for clogs or leaks. Clogged and leaky hoses are an area of concern with any central vac. Unless you hose has a hose sock, then wear and tear from constant rubbing on floors and other surfaces will result in holes and cracks. Pulling the hose can also result in leaks where the hose attaches to the handle and intake connector.
Mix some dish soap with water.
Use shop vac to blow air through hose, with other end capped or "clogged".
Apply soap solution to each end of hose.
If bubbles form, this indicates leakage. Hose will need to be replaced.
Oct 25, 2010 | Broan-NuTone CV450 Central Bagged Central...
Little Green pro heat is leaking from bottom with very little suction. I just purchased it.
Try the following suggestions for the leaking issue:
- Check to see if the black or white "duck bill" gasket is misassembled or missing from the collection tank; ensure the gasket will open where the flat flaps meet and then reinstall it. The duck bill should be inserted into the curved side of the collection tank.
- Check to see if the solution tank/cap insert is leaking.
Note: When the solution tank is filled and turned right side up, the straw on the insert may fill with water/solution causing the tank to leak for a couple of seconds. This leaking should subside after the straw empties out.
- Check for proper placement of the o-ring on the cap insert. The o-ring should be between the bottle and the insert piece (part with the "straw").
Try the following for the suction issue.
- Remove the Collection tank and locate the circular motor duct on the base of the machine. Turn the machine on and feel for suction at this location. If you feel suction proceed as follows:
- Remove the gasket from the bottom of the Collection Tank. Ensure that this gasket is open (not sealed shut) at the top of the gasket where the flaps meet. If the end is not open, simply squeeze the end to open it. The “duck bill” shaped portion of this gasket should align with the rounded side of the Collection Tank.
- Check to make sure there are no cracks in the flexible vacuum hose or in the tool you are using.
- Make sure the collection tank latch is locked down securely.
- Check for suction at the end of the hose with the attachment off by suctioning water out of the sink or a cup. If there is low/poor suction, check the hose for clogs by raising the hose handle above the unit to allow the water to go into the collection tank.
The issues may be related as you can see some of the suggestions are similar.
Aug 04, 2010 | Bissell 1425 Little Green ProHeat Handheld...
No suction on electrolux glider
Two things are the common causes for this.
1. Clogged hose. Drop a marble in one end and allow it to roll out the other. If it doesn't, there's a clog. Trying attaching the hose to the exhaust port and turning it on. This may blow out the plug if it's not packed too tightly. If it's clogged and this doesn't work, try taking it in to a vacuum service center.
2. Leaky hose. Even seemingly small leaks can result in a lot of suction loss in a long hose. Leaks result from normal wear and tear like dragging on the floor, or abuse like being stepped on or improperly stored.
There are no fixes for a leaky hose, simply replacement.
Jun 27, 2010 | Electrolux Central Vacuum
Vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Sep 11, 2009 | Kenmore 22512 Bagged Canister Vacuum
Hoover tc5238 bagless cylinder vacuum cleaner - no suction
You have a clogged hose. Sometimes a Q-tip or something like that gets sucked up and then stuff jams up against it. You can use a long stiff wire with a hook bent in the end to reach the jam and work it loose. Just be very careful not to poke the wire through the hose! Work slowly and get the clog out a bit at a time.
The clogged hose would also account for the red light.
Apr 08, 2009 | Vacuums
Eureka Bravo II poor suction at hose
check if the hose is clogged or the fan is broken
Jan 04, 2009 | Eureka 7606 Bagged Upright Vacuum
Great hose suction, awful floor performance
Lose of suction usually means a clog either in the hose, dirt inlet by the brush roll and clogged filters. But a belt that has stretched to where it won't turn the brush roll under load will make it appear as no suction. If you have replaced the belt in a while, I would try that.
Apr 24, 2008 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Suction loss?
hi samdan... have you checked all the hose attachment vents .. ie Under the vacuum as well... How long is it since you replaced the filters?
Try giving the Yellow cone inside a blow out. these tend to become clogged from time to time!
Regards Faggly
Mar 21, 2008 | Dyson DCO3 Absolute Bagless Upright...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
190 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
