SOURCE: Need Tech. Prog. Passcode
Some one has changed the pass code from the default value, the kiss of death as far as I'm concerned. Try the ADMIN option by pressing TRNF 200 and use pass code 1234, The programs you can change in that section is limited but you may be able to get to Program 601(the one you need) by using the ADMIN access. If that won't do it. You will have to get a Samsung Tech to default your system and reprogram back with the default codes.
Good luck
SOURCE: create an employee class contains following members data members:
class employee
int emp_no;
char emp_name[80];
float Basic;
public:
employee(int no, char *name, float basic)
emp_no=no;
emp_name=name;
Basic=basic;
float int calc_da()
return(Basic*52/100);
float calc_it()
return((Basic+calc_da())*30/100);
float calc_netSal()
{return(Basic+calc_da()-calc_it();}
SOURCE: VLOOKUP Formula
Using IF function or filter to generate the membership type and create a VLOOKUP for that..... Or using filter function you could create a pivot and insert the specific formula per type in that.
SOURCE: I recently purchased a home
Here is your manual:
http://www.appliancefactoryparts.com/content/pdfs/10473-1.pdf
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Testimonial: "What a great service!"
