Display driver problem
When I try to install a fedora linux in my machine , ATI Radeon Xpress 200 series doesn't support graphics display.
  • 983 Answers
Ya there is a problem with driver while installing fedora core 4 i think ... u must have also tried in that only ... so i suggest you to install other version of linux... there are many other versions available like ubuntu,mandrake,redhat. or you just give try with installing the latest version of fedora core ...( try fedora core 6 or 7)..
as linux is a open source for all you can download it from net for free.............
Posted on Feb 08, 2008
Nvidia geforce g210
1.5.1 Graphics Subsystem
The board contains two separate, mutually exclusive graphics options. Either the integrated
graphics processor (contained within the ATI Radeon Xpress 200 Northbridge) is used, or a PCI
Express x16 add-in card can be used. When a PCI Express x16 add-in card is installed, the ATI
Radeon Xpress 200 Northbridge graphics controller is disabled.
Mar 06, 2014 | Intel Computers & Internet
Dell dimension 5100
If you are having problems with your video card
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or
you might need to download one
This package supports the following driver models:
  • 128MB ATI RADEON X600 SE
  • 128MB ATI RADEON X600 SE Secondary
  • 256MB ATI RADEON X600
  • 256MB ATI RADEON X600 Secondary
  • RADEON X300 SE 128MB HyperMemory
  • RADEON X300 SE 128MB HyperMemory Secondary
  • RADEON X300 Series
  • RADEON X300 Series Secondary
  • RADEON X600 256MB HyperMemory
  • RADEON X600 256MB HyperMemory Secondary
  • 128MB ATI Radeon X1300
  • 128MB ATI Radeon X1300 Secondary
  • 256MB ATI Radeon X1300PRO
  • 256MB ATI Radeon X1300PRO Secondary
  • ATI Radeon Xpress 1100
  • ATI PCI Express (3GIO) Filter Driver
Hope this helps you
Aug 07, 2011 | Dell ATI RADEON X300 SE, (128 MB) PCI...
Im trying to disable the on board graphics card so i can install then new on i just bought. i have a gateway GT4024 and the onboard graphics card is an ATI Radeon Xpress 200 series
Your board has ATI integerated graphics, no need to remove. You would upgrade by adding a PCIe express card in slot. Do you have such a card? If you need installation instructions, let me know at "add a comment"
Apr 06, 2011 | Gateway GT4024 PC Desktop
When I watch a show from youtube or when I use a programme that require much graphic, my screen will have an instant black out and recover from the blackout followed by a notification which states:...
There appear to be problems with alot of different software and windows 7 as faras compatability. In my expierience, you never want to allow any upgardes to ATI/AMD through windows., I learned that the hard way. They ar not compatable and usually immediately screw up resoulution and send you searhing for a way to fix the picture(blue screen). The third link is AMD's link for updates which should work for you. If this doesn't help let me know in "add comments" at end of solution.
Mar 17, 2011 | Intel D102GGC2 Motherboard
I need the audio & vedio driver ddr101
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 01, 2011 | Intel D101GGC Motherboard
I have intel D102GGC2 motherboard with ati radeon xpress 200.can i play movie smoothly in windos 7 32 bit? i have p4 processor.
ATI Radeon xpress 200 driver is installed automatically in windows 7, however if you face problem with the drivers you can download the latest drivers from the links below
Download ATI Radeon Xpress 200 WDM Integrated Driver v.10.2
Download ATI Radeon Xpress 200 Catalyst Software Suite v.10.2
if you require more assistance regarding this feel free to reply to this post
Jan 13, 2011 | Intel D102GGC2 Motherboard
ATI Radeon Express 200 series comapred to ATI Radeon 8500
Hi. The ATI Radeon Xpress 200 is better than the Radeon 8500.
Aug 19, 2009 | ATI Mobility RADEON Graphic Card
Will intel D101GGC support ATI Radeon 8500?
yes, before you buy video card
verify first the interface slot available on *********** board (AGP,PCI or PCI Express)
then select the video card with the same interface in *********** board
verify the video cards driver if compatible to your operating system
before installing the video card update your BIOS to latest version
Mar 20, 2009 | ATI RADEON 8500 Graphic Card
ATI Mobility Radeon? X2300 graphics driver for Fedora
If you install the Fedora 9 preview it should resolve this issue.
May 02, 2008 | ATI Mobility RADEON Graphic Card
Computers & Internet Logo
231 people viewed this question
David Payne
David Payne
