Question about Kenmore Washing Machines
My Kenmore Elite keeps flashing LD after I start to wash. Then the machine stops washing. Clothes are not wet, but I heard water going into the machine. How can i fix this?
  • 15,935 Answers
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 11, 2010
My Kenmore Elite Calypso wont stop washing
What is the model number of your unit?
Nov 22, 2012 | Washing Machines
Washing machine stops half way thru and flashes code LD?
Long Drain
Ld flashes when the water level does not change after the drain
pump is on.
Is the drain hose clogged?
Is the drain hose height greater than 96′?
Is the pump running? If not, see TEST #7, page 13.
May 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
I have a kenmore elite top load washing machine. It keeps giving a code of ld. Ceral number is SM 9711024
Hello, LD stands for long drain.
If all the water isn't out of the unit within a certain time, the ld will flash.
Could be 2 things.
1) There's lint stuck in the pump preventing the water to drain properly or
2) You're using too much soap causing lots of suds also preventing the pump from draining properly. If this is the case, what you need to do is run the washer on full load with no detergent and clothes. Let it go thru the cycle and get rid of eccess suds. This is most likely your problem.
Best of luck :)
Aug 19, 2009 | Washing Machines
I Kenmore Elite mod# 110.22062102
The "Ld" error means long drain. May require a new pressure switch
Aug 03, 2009 | Kenmore Washing Machines
What does LD mean in the LED time screen? it fills for a min then stops and flashes Ld
Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Jul 28, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
79 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
