Question about Nokia 1661 Cell Phone
The alarm clock on the nokia 1661 goes off before the time set,have to reset alarm everytime, multiple times throughout the night.
Apparently there's a bug in the auto time update function - turn off auto time update and the alarm will work correctly.
Posted on Jul 30, 2009
Alarm clocks
Depress and Hold the TIME button. Depress the HOUR button to multiple times until you get the correct hour showing. Pay attention to the AM/PM indicator to make sure. Then Depress the MINUTE button multiple times until you get the correct minute showing. Release your hold on the TIME button.
Jan 25, 2014 | GE 7-4894 Clock Radio
The buzzer goes off at 12 midnight every night
You probably have an alarm feature on the radio.
The common default time for timepieces is 12:00.
Find the alarm setting and set the alarm off.
If you cannot turn it off set it for 11 am.
Aug 29, 2011 | GE 7-5290 Clock Radio
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    I find the controls very confusing and when attempting to set the clock to the day's time, usually end up changing the preset radio channels or mistakenly set an alarm that goes off during the night... are...
    Press "set" one time to set alarm one, two times to set alarm 2, and 3 times to set the time. Use the "tune/time" buttons for forward and backward. If you wait too long to push one of them or stop too long, it will time out and go back to the last setting.
    Be sure to press "set" when you are done, before it resets to the prior setting.
    Feb 06, 2011 | RCA RP3710 Clock Radio
    Nokia talking alarm clock
    try logging on to torrent and search it. surely you will find one.
    Sep 08, 2009 | Nokia 1661 Cell Phone
    HSD128A projection clock came with chinese instructions
    Here is the PDF of instructions. http://www.tinxi.com/download/88028_en.pdf
    Mar 30, 2009 | GPX D725 Clock Radio
    Change startup tune
    Use this steps to get to changed the nokia tone Menu > Tools > Settings > General > Date and Time, then scroll to "Clock Alarm Tone", from here you can change the alarm to a quiet beep.
    Regards
    Feb 20, 2009 | Nokia E71 Smartphone
    Alarm goes off randomly
    Sir, first check that the status of automaic updates of date & time on your handset. If that is off please turn it ON as is ur handset gets resetted from time to time it will take the service providers date & time which is almost accurate. If this doesnt help then try replacing the battery.IF that doesnt help then only one thing can be done A software Reflash. Take your handset to a repair workshop & have the firmware flashed. Thats the final solution.
    Thank u
    Oct 15, 2008 | Nokia 1600 Cellular Phone
    T-mobile dash multiple alarms
    The solution is a follows; If you have any legit alarms already set, disable them before proceeding
    1) As soon as the unwanted alarm goes off , look at what time your phone says it is and make a note of it. (if you know EXACTLY what time it goes off at, then go to the next step)
    2) Goto Start -> Clock & Alarm -> Alarm
    3) Set the alarm time for the exact time from step #1. Set alarm to On.
    4) Click Done, done, and done
    5) Goto Start -> Clock & Alarm -> Alarm
    6) Change the alarm to Off.
    7) Click Done, done, and done
    That's it, the alarm should now be disabled for this unwanted alarm, if you have multiple unwanted alarms, repeat this procedure for each.
    Dec 11, 2007 | T-Mobile Dash Smartphone
    Nokia 1661 Cell Phone Logo
    682 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
    IT Solution
    IT Solution
