Question about Orange Knog Frog White LED light
I have a knog LED light with two AAA battiers, but how do you remove them? Can't locate opening without tearing the plastic
  • 32 Answers
Check this website: click here. Use the zoom to look at the instructions at the top of the picture.
Hope this helps.
-samson39
Posted on Jul 27, 2009
Replace batteries
Marcia Boal... hello,
If our battery has corroded it may be impossible to get the end (opposite the light) cap to come off. The light is designed to be moisture resistant... Likewise even penetrating oil cannot get in...
To guarantee long reliable service it is best to put a tiny dot of grease on the threads on assembly.
Maglite Solitaire makes a wonderful little flashlight...
(all metal construction... single AAA battery)...
((Mini = 2 AAA batteries... opens the same)).
Basic colors included black, red, silver & blue
but this particular light was also quite popular for commercialization... often displaying many BIG NAME
COMPANY LOGOs.
The initial closure of the end cap can be quite loose to be effective because of it's O-ring design... however some folks put the end cap on too tight...
The
It might take some serious force to get it open again.
Consider using a piece of leather in a pair of pliers to avoid marring the case. Reassemble without over-tightening.
Hope this helps!
Maglite Solitaire Incandescent 1 Cell AAA Flashlight Black Basic Handheld...
Amazon com Maglite Solitaire Incandescent 1 Cell AAA Flashlight Blue Home...
Maglite Solitaire LED 1 Cell AAA Flashlight Red Basic Handheld Flashlights...
Maglite Solitaire LED 1 Cell AAA Flashlight Silver Basic Handheld...
Aug 19, 2016 | Camping, Backpacking & Hiking
Door wont open locking rods detatched door wont open.how do i fix this
Sorry to say you will need to remove your inner door trim (panel) off. It will be impossible to get to the locking linkage without removing the panel. There are clips which hold the panel to the door, slowly and carefully remove. The real problem will be getting to the linkage which might mean removing or re-locating wires and other parts that get in the way. The problem is that most of these locking linkage are held together by plastic clips and they due tend to break quite often. Very easy to replace and the plastic parts are cheap. Do remember to replace all the plastic parts/bushings for the problem door side. You do not want to go back again to just replace another plastic part because another part broke and you were too lazy to replace it when you had the chance. I did! ;(
Feb 19, 2015 | Cars & Trucks
Were is the door jamb switch locate on a 2002mercuary mountainee
Looking at the driver's door, with the door opened, you will see a large black plastic housing which protects the wires going into the door. It's inside that plastic housing. Before you go tearing things apart, first locate the dash lamp dimmer switch and make sure that it is NOT turned down all the way. If it is, that may be the problem. Also check for a blown fuse.
Sep 21, 2014 | 2002 Mercury Mountaineer
How do you install new batteries in my Kensington PocketMouse 72214
i have the mini m. for awile want to install in another notebook dont remenber how> helpppp
Sep 23, 2010 | Kensington PocketMouse 72214
I have a knog skink bike light - how do you open it up to change the battery?
try going to their web site - they have all their manuals there very helpful with pictures of how to do it! http://knog.com.au/techmanual.aspx#
May 13, 2010 | Knog Bike Light Gekko 3 LED Headlight
The AAA batteries are easy to change. Take out The silicone casing. is a bit fiddly when you try to put the lights back in, but this is easily circumvented once you realise it's almost impossible to tear it).
May 13, 2010 | Cycling
Plastic covering
get some wide tape like packaging tape and tape the plastic. start from one end and pull on the tape, the plastic should come off with the tape. then you can clean up the small peices.
May 22, 2009 | liftmaster Chamberlain Garage Door Opener...
Hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Monitor wont power-up
It is usually the Large Value Caps around any heatsinks etc. in the Power Supply.. I usually simply replace ALL Large Value Electrolytic Capacitors, with same or better temperature ratings. This often fixes any problems.
Jul 01, 2007 | CTX F973 19 in. Flat Panel LCD Monitor
Orange Knog Frog White LED light Logo
111 people viewed this question
Top Orange Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you an Orange Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
