SOURCE: receiving e-mails but unable to
Check your SMTP settings to make sure you are using the right port numbers.This is usually 25.List any error messages you may have.
SOURCE: Gmail POP3 Error
Set your gmail profile in your gmail account, by allowed pop3 system software download your mail from gmail
SOURCE: unable to receive mail in Entourage from POP server.
Not really sure what is wrong but would suggest that you check your account setup under tools/Accounts and see if the setting for advanced settings for receive is set to "This POP service requires a secure connection" is checked or not. It depends on what your ISP requires
SOURCE: Receiving but unable to send for approx 14
You might check this site: http://www.oehelp.com/OETips.aspx#3
You did not mention whether you were using antivirus software to send or receive filtered e-mail. I tried looking up your error code-and one common theme I saw was that you should turn it off. It causes problems and does no real good since the high end viruses just send directly from their own code.
However, another thing I saw was that people had errors in their setup.
You imply that this used to work and stopped suddenly. You might still try deleting the mail destination and then re-adding it, insuring that your userid and password are specified correctly, and that you have not inserted any extra spaces, capitalized when you should not, etc.
Finally, open a command line and then enter the command:
telnet yousmtpserver.net 25
where you type the name of your smtp server as specified in your isp's connection stuff.
This to test the ability to reach your ISP's smtp server. See, some ISPs block outbound connections to port 25 - to stop spambots from sending from people's home computer. If it turns out that you can't connect to port 25 on your mail provider's smtp server, sometimes they have an alternate port that you can use. By default the "submission port" (which is only supposed to be used by customers inserting mail initially) is 587, while 25 can be used as a submission port or it can be used by another ISP as they transfer mail to you. So you could try telnetting to port 587 or you could try just specifying 587. But first turn off your anti-virus outbound mail filtering and see if that helps.
SOURCE: Still not receiving mail at
Hi jack406,
This is an error on hotmails part, please do the following:
1. Start Windows Live Mail.
2. On "Tools" menu, click "Accounts."
3. Select the account that you want to be removed and then click "Remove."
4. Click OK.
5. Now, Start Windows Live Mail.
6. On the Menu bar, click the "Tools" menu.
7. Click "Accounts."
8. Click "Add."
9. On the selection box, choose "E-mail Account" and then click "Next."
10. Type your e-mail address, password, and display name on their respective boxes. Click "Next."
11. Click "Finish" to complete set-up.
If this does not work, this is an internal server issue and only windows live tech support can fix it. Here is the link to post your issue so tech support can fix your hotmail.
Please go here.
http://windowslivehelp.com/thread.aspx?threadid=506899b3-41be-44d3-ad2b-5399e7b6f76d
Then click reply at the bottom of the green message from windows live Mark V.
Then type in the full error message your getting.. and they should be able to go into the server and fix this issue for you.
Hope it helps.
Thank you for using FixYa.
