Question about V, Inc. Vizio P4 Plasma Television
Vizio 19" LCD Tv Dvi to HDMI shows "no signal" after power cycled
I just bought a 19" vizio LCD TV to use as a monitor with my computer(DVI to HDMI). I power the TV off when Im gone, but when I power it back on the HDMI input shows "no signal". The only solution Ive found so far is to turn the computer off and back on. Another note, when I power the TV off the computer makes the sound of a device being disconnected. The computer Im useing has Windows 7 RC, but Im not sure thats the problem, seems more like a hardware issue. (Ive found similar problems online, but havent found any solutions yet.)
Noggin
  • 944 Answers
SOURCE: hdmi/dvi
Here is the link to the user manual for the TV if you need it; http://www.haier.com/admin/en/product/upload/42EP24S-UM.pdf Check page 7 - The DVI input has next to it an audio input - DVI does not carry audio as HDMI does - you need to plug a seperate mono audio cable from your cable box to the TV at the DVI Audio input (top of page 12). The Audio needs to be in the one next to the DVI socket in order to work at the same time as the picture from the same "source" selection. Check page 18 "CATV Type" and make sure this is set to the correct one for your cable box Check page 21 that all the audio settings are logical and nothing is turned right down or muted. If none of this helps then please post back. What make and model is Your Cable box? Hope this helps :)
Posted on Aug 21, 2007
SOURCE: Connecting an LCD TV to a computer to use as TV and Comp. Monitor.
Im no expert on the subject, but I use my L37 for a monitor, and use just the vga adapter. It works good as a monitor, and both dvds and my hdtv wonder tuner card look great through the vga connection. They do make adapters for dvi to hdmi. Although, hdmi also carries sound, but you wont get that out of your dvi output from your card. So you might not have sound when using that connection, as your tv may not look to the headphone type jack used for sound imput from your computer when you select the hdmi source on it. If you have speakers already connected to your computer you may not care. Also if you have a 720 p Vizio, 1366x768 is the highest resolution you are going to get out of it anyway, if I'm not mistaken. I'm Not sure why you would need 2 connectios to the same monitor either. I posted 1 link below because they had several dvi to hdmi adapters. Hope that helps.
http://www.bizrate.com/computercables_adapters/products__keyword--hdmi+dvi+d+dual+link.html
Posted on Aug 01, 2008
SOURCE: Vizio 50 inch plasma picture problem
Once minute my Vizio P50HDM was working the next minute the picture was barely visible. I called Vizio and they gave me a number for a repair company. Their company gave me a $650 estimate. I called a few other local placed and they said that this is a very common problem for this model TV. All the places gave me an estimate of between $600 - $700. I called Vizio to complain, but they are not interested.
Posted on Sep 06, 2008
SOURCE: Vizio P4 Plasma TV, won't turn on
if your vizo p4 blinks red 10 times its your power supply board ckeck your two fuses on the board,if those are not bad change your power supply board if you can find a board for that model vizio p4 .the phillips tv uses the same board
Posted on Oct 15, 2008
SOURCE: Another dead Vizio... P50HDM
95% Y and Z sustainer boards since you alweady had red pixels.
Posted on Jan 19, 2009
How do I convert a Westinghouse 22" LCM-22w3 DVI/VGA LCD Monitor into an HDTV?
Dear Amy,
Normally, monitors do not have tuning electronics for capturing TV signals.
Therefore, consider the monitor as a "dumb" unit that only displays information coming from your computer. Also, this unit does not have a HDMI input, but only VGA.
So, you are fated to have this monitor connected to your computer, always.
Now, you may find good software that will "tune" the TV signals from streaming at the Internet and show whatever is being broadcast. The same way you can access YouTube and watch videos these TV tuners will get the streaming signals the TV stations send via Internet (not all do that) and watch the channel in your PC/monitor
Since I do not have additional information about the computer you use I cannot give you other ideas
I hope I have helped you.
May 18, 2014 | Westinghouse 22" LCM-22w3 DVI/VGA LCD...
Hp w1907 VGA no input signal
its is telling you the truth (99.9999999% of the time)
believe it !
no PC stated
no TV model stated nor clear connections stated.
are you trying to get the PC (the tower means that)?
to run to video concurrent ports at the same time?
so do both fail,
VGA side
and DVI side,
you never said.
hard to help lacking
what TV
what Tower
what connections, and special adapter (HDMI)
the TV has DVI??
sorry, cant see what you have there. at all.
Feb 01, 2018 | HP w1907 LCD Monitor
Can i turn my vizio m190va tv into a computer monitor?
Unfortunately. the HDMI port on the M190VA does not interpret the signal from a computer. The HDMI signal from a set-top box is different than that of a computer. You need to use the VGA port and the PC audio in on the TV; if your computer doesn't have a VGA port, use a DVI to VGA adapter or other appropriate adapter. You will need a 3.5 mm audio patch cable to use the TV's speakers. See page 25 of the M190VA manual here: http://store.vizio.com/documents/downloads/hdtv/M190VA/364User%20Manual.pdf .
I wish that I had better news for you.
May 08, 2012 | Vizio M190VA 19 Class Edge Lit Razor LED...
I have connected my computer to the TV with a HDMI DVI cable and still no sound through the TV.
there is a specific conflict between a pc and hdmi-dvi and producing audio. you may want to research a special dvd-hdmi cable that vizio sells, check your users manual. if you still get the same issue be sure the specs are correct and make sure your tv is capable of this type of connection, if you still can not get it, you may need to replace the main board in the unit.
Apr 16, 2011 | Vizio L32 32 in. LCD HDTV
Can i hook my 47inch tv to the monitor
You can't hook you TV to the monitor itself, rather the computer.
If your PC has a wide white connector (DVI) that is supplying signal to the monitor, you could use a DVI to HDMI adapter cable to connect your PC to your TV. This is also possible if your PC uses a small blue connector with 15 pin holes (VGA) by using a VGA cable to connect your PC to your TV.
Mar 17, 2011 | Acer AL1916W 19" LCD Monitor
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
I just hooked up my HP Pavilion 9000 Laptop to my Vizio TV and put the TV on correct setting. It is not working on the TV, any ideas? I went on Display setup and kept trying to connect but it says the...
If your laptop has a VGA port, your Vizio needs to have a VGA port too so you can use a standard VGA monitor cable.
If your laptop has a DVI port, you hook it up to the Vizio using a DVI-to-HDMI cable.
And if your laptop has an HDMI port, you hook it up using a standard HDMI cable.
Hope this helps.
Oct 16, 2009 | HP Pavilion dv9000z Notebook
Blank Screen using HDMI-DVI cable for PS3
Sounds like your LCD monitor isnt HD compatible.
Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
VIZIO VO42LF says no signal when connect to PC after power on/off
Could be a sensitivity problem, have you tried to switch tv modes back and forth, sometimes if you do that it will save you from restarting the computer. I had a tv about 10 years ago that had a sensitivity issue, went to see about fixing it, unfortunately, the tv brand was no longer in the country and user service parts were not available.
Apr 11, 2017 | V, Inc. Vizio P4 Plasma Television
Jul 18, 2008 | Vizio L37 Television
V, Inc. Vizio P4 Plasma Television Logo
618 people viewed this question
Top V, Inc. Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
rostit
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
