Question about Dell Inspiron 1150 Notebook
1150 dell inspiron. Laptop won't power up. If
1150 dell inspiron. Laptop won't power up. If battery is inserted, when the power buttton is pressed the power indicator turns green and the battery + indicator turns yellow. If the laptop is plugged directly into the wall with no battery, the same lights come on and stay on with out powering up the unit.
  • 479 Answers
This seems an issue with inverter board need to checked by an expert.
thanks
Posted on Jul 27, 2009
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Dell inspiron 1300 won't boot
If you want to keep your important data, use some softwares can solve thewindows won't startproblem most quickly, and no data will lose. Besides, it is very easy, even the people who lack of computer knowledge can deal with windows won't boot issue.
Sep 21, 2012 | Dell Computers & Internet
Dell inspiron 1501 won't boot but caps lock flashes continuosly. when i remove memory it doesn't beep
Caps lock flashing indicates faulty memory - it's a POST (Power On Self Test) before BIOS executes. When memory is removed it should indicate "no memory". Carefully re-insert the RAM memory module, check the tiny contacts inside the connector on dust. Then try again.
If there are 2 memory banks (1 one the back, the other under keyboard) remove one RAM memory module.
If capslock keeps on flashing test it with another RAM module.
Jun 30, 2011 | Dell Inspiron 1501 Notebook
Dell inspiron 1525 battery not charging
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
Inspiron 1150 lights up but no display at startup
disconnect all power cable, battery, then press the power botton for 1min. try reset the RAM, then connect power cable and battery and press fn & power button if still it doesn't have any display then you need to change the m/b
Dec 18, 2009 | Dell Inspiron 1150 Notebook
Laptop will not turn on.
Bad motherboard. Black Christmas is around the corner. New laptops are running 200-300. Time to save up for one...sorry :(
Nov 21, 2009 | Dell Inspiron 1150 Notebook
New power adapter and new battery, wont charge through power chord, dell inspiron 1150
If ac adapter and battery have been replaced (Dell Branded AC adapter is required) then the only thing left is motherboard.
Oct 28, 2009 | Dell Inspiron 1150 Notebook
Inspiron 1150 won't turn on. Noticed recently that battery life seemed shorter, plugging it in did not prevent it from shutting down after receiving the low battery warning, and it took a long time to re...
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 18, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
No lights when power button pressed. acadapter shows power
Try a different outlet....
if that doesn't work, then...
Your Battery Might be damaged. (partially charging any type of rechargable battery/pack can substantially shorten the lifespan of said battery.) I would take your laptop to a repair shop or store and have the battery tested as well as the AC adapter.
Apr 20, 2009 | Dell Inspiron 1150 Notebook
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 1150 Notebook Logo
458 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
