Question about Toshiba 32A33 32" TV
Tedelex colour TV
This TV does not swicth on at all
Re: Tedelex colour TV - Toshiba 32A33 32" TV Standard (CRT) Televisions
No vol, no change of chanel
Posted on Sep 14, 2008
    Problem Solver:
  • 9 Answers
first check the fuse in the plug.if its ok then the fuse in side the tv might have blown,if you are going to check the fuse in side the tv your self PLEASE make sure that the tv is NOT plug into the mains and be very careful that you do not touch any of the circuit boards as you will/might get a electric shock..the fuse might be a 20mm glass type,inside the fuse you should see a piece of wire if this is broken then that is the fault,if you cannot see the wire then you will need a meter to check the fuse. if you have no meter to check the fuse then take the fuse to a tv shop to check..hope this will get the tv working,if not then im afraid the tv will have to be taken in for repair..all the best..Lee Bruce.
Posted on Nov 22, 2007
0 characters
3 Points
How to fix a paktex new remote to my tedelex tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Feb 08, 2015 | Standard (CRT) Televisions
How to degauss a tedelex ec2175 crt tv?
Contact any service technician; who have external degausser in hand. Electro help
Sep 20, 2014 | Standard (CRT) Televisions
My tedelex ec21e09g tv lost its colour its greenish n grey people
Check its video output stage circuit board; for any loose solder terminals. This card can be located at the back of the picture tube, will directly plugged to its back. Absence of blue is the reason.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 23, 2014 | Standard (CRT) Televisions
I have tedelex 100hz tv the problem is the screen is shrinking can you please help solve it
Check and replace damaged component/s at its main power regulator section circuit. The voltage comes out from this section goes lower than normal. Contact any service technician. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 27, 2014 | Standard (CRT) Televisions
If I am not mistaken this sounds like an older model tv and your best bet is to google the word tedelex and go into the Tedelex - South Africa title and contact them they should have a copy for you.
Apr 14, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tedelex ec29e12 tv not switching on
Check and replace damaged component/s in its power supply regulator section circuit.
Oct 05, 2012 | Standard (CRT) Televisions
As power on tv try to start but swicth off
set the proper screen voltag. adj e.h.t. driver trans c337.c327. 47/63v cap.near l.d.t. c.r.t pcb check 18 k* 3 nos . ik res 220 ohms. change trans f422 f423 all
Mar 21, 2009 | Philips 20PT643R 20" TV
Tedelex TV
would it be reccomended to buy a tedelex tv
Dec 15, 2007 | Samsung TXN3271HF 32" TV
Tedelex TV
tv screen locked a padlock appears in the screen.
Nov 23, 2007 | Toshiba 32A33 32" TV
Toshiba 32A33 32" TV Logo
398 people viewed this question
Top Toshiba Standard (CRT) Televisions Experts
Jaime Hernandez
Are you a Toshiba Standard (CRT) Television Expert? Answer questions, earn points and help others
