Question about IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6---when I turn it on, it appears to lock
When I turn on the typewriter, hammer returns to far left, "pecks" one time and appears to lock. Line space lights 1 and 2 flash and it won't type or do anything. HELP
  • IBM Master
  • 3,594 Answers
There are a few possibilities. First lube the silver shaft that the carrier slides on (WD40 works well). Remove the printwheel and check for paper or ither debris in that area. After that you e
will probably need a tech.
DickyO
Posted on Jul 28, 2009
Carriage will not return on 2 of our IBM Wheelwriter 6, can this be fixed?
First spray some WD40 on the silxer shaft that the carrier slides on they get really gummy, if this works run it back and forth a few times then clean the shaft off with a rag.
DickyO
Jun 25, 2015 | IBM Wheelwriter 6 Typewriter
Where is the TYPEWRITER SOLENOID on a IBM Wheelwriter 6 Series II
The "print" solenoid is what hits the hammer that hits the printwheel and makes it type on your paper. If you remove the ribbon and look straight down in the carrier on the left side you can see the solenoid. It is below the blue piece of rubber that sits on the hammer arm. The end of the solenoid is supposed to have a cap on the end of the plunger. This cap gives a specific clearance so when it is activated, it hits the hammer arm to propel it forward to strike the printwheel.
Apr 28, 2014 | IBM Wheelwriter 6 Typewriter
Ibm 6747 w'ont write (hammer w'ont hit)
Your print solenoid probably has a broken cap. There are some companies that sell the "kit" with instructions on how to replace the cap.
Jan 16, 2014 | IBM 6747 refurb typewriter wheelwriter 6...
IBM Wheelwriter 3 won't type
Print hammer selenoid cap is broken, or print hammer selenoid is gummed up.
Jan 03, 2014 | Lexmark Wheelwriter 3 Typewriter
The left margin is stuck and the release margin works only the first time after turning on the typwriter. I can set the margin at a point on the left side, but after a few times of hitting the return key,...
Put a shot of WD40 on both sides of the silver shaft that the carroer slides on. If that doesn't do it put some on the carier motor bearings. The front one can be reached from inside of the T/W the rear one yuo will have to remove the case of fish the straw thru it. The motor is located on the R. rear corner.
DickyO
Apr 05, 2011 | Lexmark Wheelwriter 1500 Typewriter
Wheelwriter 6 stopped printing. everything works
Tou most likely have a broken print solenoid cap. We sell them for 20.00 includes instructions and shipping.
DickyO
Cleveland Business Machines
216-242-0027
Apr 23, 2010 | IBM Wheelwriter 30 Typewriter
Wheelwriter 6 typewriter hammer no longer strikes
It is pretty common for the pad on the solenoid to strike the keys wears out, and for the batteries to be dead for the memory. Your machine probably needs a good cleaning, oiling, and a new pad for the striker. about $100.00 in the shop.
Jun 30, 2009 | Office Equipment & Supplies
IBM Wheelwriter 6 Problem
The lights blinking indicates an error code, that mean a keyboard error or posibly a problem in the start up procedure. This is a problem that would have to be solved in a repair shop.
Oct 27, 2008 | IBM Wheelwriter 30 Typewriter
IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Oct 31, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Wheelwriter 30 Typewriter Logo
133 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
