Question about GE Refrigerators
Ice maker was not hooked up for a long time, once we hooked it up, the water does not stop once the trays are filled up,how do we get the water to stop over filling the trays?
  • GE Master
  • 1,606 Answers
I would start by replaceing the water valve . The piece which connects from the wall to the ffridge .
Posted on Jul 27, 2009
How do I stop my ice maker water filler hose from freezing - which stops water from filling the tray?
This problem is caused by a defective water control valve that does not stop leaking water like a dripping faucet. This causes water to freeze in the water fill tube thus blocking fill of ice tray. Replace water control valve.
Appliance 911 Sea Breeze
Sep 19, 2015 | LG Refrigerators
The drip pan is filling up with water and then over flowing. We have to empty it once a day. Then I noticed the ice maker has stopped making ice. Any ideas?
Turn icemaker off see if water problem stops ice tray water valve may be overflowing tray cycle timer may be faulty or faulty water control valve.
Jul 31, 2015 | Whirlpool Refrigerators
Maytag msd2758ges ice maker squirts water
Sounds like the water solenoid is not shutting off cause once the tray fills it should stop sending water located in the back bottom with the water lines connected
Mar 24, 2013 | Maytag MSD2756GES Side by Side...
Ge s/s icemake floods water
Icemaker generally has only about a 6 second fill time. Most likely a particle made it past the screen in the fill valve and would not allow the internal diaphram in the valve to seal. You can't get to the internal parts of the valve. Replace the valve. Consider an in-line filter installation before the refrig hook up to prevent this from repeating.
Jun 14, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
GE TFX24F Ice maker does not stop filling
did you try pushing up the arm on the side of the ice cube tray
Jun 17, 2009 | GE Refrigerators
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Jan 04, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Kenmore Ice Maker Problem, Side by Side Refrigerator
Thanks for the question There is a water valve just for the ice maker so the problem could be there if you have a volt meter you can check the valve what you can do to check the valve reverse the wires onthe valve and push your water dispenser if no water goes into your ice maker . you have a bad valve replace thanks for the question The appliance doc
Oct 23, 2007 | Kenmore 53603 / 53606 Stainless Steel Side...
Ice Maker Not Making Ice
There is no pump per say.. the water pressure is all that fills the ice maker and provides water to the drinking dispensor. The solenoids are also different, one activates for ice maker and the other for drinking water. The fastest way to check water flow is to swap the wires on the solenoids so the drinking water "power" will now power the ice fill solenoid. Once the plugs are swapped and you press the drinking water lever the ice maker should pour water out the fill tube. If that works then you know the solenoid, tube, etc. are all fine. I'd suspect then that the ice maker fill solenoid isn't getting power when it is suppose to fill. Let me know what this test result is.
Jan 23, 2007 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
