Question about Hotpoint RVM1635 Microwave Oven
Same problem but without the noise!
My microwave will activate and everything fin but it barely heats it at all!
    Guru:
  • 1,894 Answers
You probably have a bad magnatron tube. this is the heart of the system and works by exciting the molecules to heat. If you don't hear the tell tell buzzing noise then it is the mag tube. They can be costly to replace
If the timer, lights, menu, etc, all work, but the tube does not turn on (the typical power noise), could it possibly be a problem with the interlock from the door/handle when it is closed?? (the safety switch that keeps the magnetron from exciting the water molecules in the skin on your face/hands and your eyes)?? Its in the housing where the door latch inserts. Just a thought as I have seen the same prob, but if the tube sounds like it goes on (usually the lights may slightly dim from a tube's power drain to help indicate that this is the case), then your tube may not be fully functional, if at all.
Posted on Jul 27, 2009
Microwave made a loud grinding noise while heating a cup of coffee for 1 minute,now everything is shut off. We checked the curcit breakers all ok, and there is power going to it!
see this causes and fix it. God bless you
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Oct 15, 2012 | Microwave Ovens
Turn microwave for 3sec after it start arking noise
Take warm soapy water and clean until spotless, food partical build up will cause arcing, if no change! the microwave hood is a another trouble spot, if any bare metal is showing it will arc and need to be replaced, if everything checks out the magnetron is bad and will eventually fail.
Mar 20, 2012 | Samsung SMH7178STD Microwave Oven
Please help me locate and test magnetron on my micro
NOTE: Microwaves have a capacitor in them which can give you a massive shock!!! Be careful what you touch.
You need to remove the outer metal cabinet, you will then see a large square box with fins on it, this is the magnetron.
About the only thing you can check is the inline fuse inside the microwave, it will be in one of the wires that runs to the capacitor and you can check this with a multimeter . If the fuse is ok then the fault will be with either the capacitor or the magnetron, neither of which can easily be tested without specialist equipment.
Mar 07, 2012 | Emerson Fans Microwave Ovens
GE PEB2060 Control panel and everything seems to work. Makes all the right sounds but the microwave just stopped heating. It is barely a year old.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 17, 2011 | Microwave Ovens
Frigidaire microwave won't heat
Generally the magnetron (the part that heats the food) is the cause if everything else still works and it only works once in a while, possibly a short, but not as likely. Unfortunately replacing the magnetron is barely cheaper than buying a new microwave though you can check out repairclinic.com to decide whether you want to attempt replacing the part.
Let me know how this works out for you.
Benjamin
May 24, 2010 | Frigidaire PLMV169DC Microwave Oven
My Maytag microwave stopped heating. Everything
Generally the magnetron (the part that heats the food) is the cause if everything else still works. Unfortunately replacing the magnetron is barely cheaper than buying a new microwave though you can check out repairclinic.com to decide whether you want to attempt replacing the part.
Benjamin
May 24, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
Powers but no heat. Everything else functions
Sounds like the magnetron has failed. This is the component that produces the microwave that heats the food. The cost of the magnetron is about 95% of the cost of a microwave . Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Jun 30, 2009 | LG LMV2053 Microwave Oven
It doesn't heat up
When the microwave won't heat, but you hear a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. We recommend that you consult with a qualified appliance repair technician for help in determining the problem and deciding what to do about it.
thanks and please do not forget to accept the solution
Apr 03, 2009 | Kenmore Microwave Ovens
Microwave not heating food
The problem you are having with your microwave is a common one. Not heating is a problem that can be caused by three things. I'll list the most common solution first, the magnetron that actually does the heating is what is making that noise and has gone bad. It is possible for you to also have a bad high voltage diode that has opened up, solution two, or solution three is the high voltage capacitor is not working properly as well. From my experience with microwaves I am positive that it is your magnetron that is bad. If you are not do it yourselfer you'll need to take it to a repair shop to replace. However, if you know how to use a screwdriver and can unplug a couple of wires with spade terminals on them, then you can take it off yourself, find another one and replace it the same way you took it off. The magnetron sits behind the control panel of your microwave but on top. It has cooling fins on it and has 2 terminals maybe three depending and make and model that plug into it. It has 4 screws that are easy to get to that actually holds it in place. If you do not have a good local source like an electronic parts supply place then you can find the right magnetron at www.mwoparts.com. Be sure you always unplug the microwave before touching or trying to take the he cover off and then when you take the magnetron off also.Good luck and God bless.
Jan 26, 2009 | Maytag MMV5207AAS Microwave Oven
Hotpoint RVM1635 Microwave Oven Logo
69 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
