Question about Apple iPhone 3G
Battery life is so short and it takes 10 hours to fully charge it
The battery logo is so crazy. like now, its half then a few seconds later its full then goes to the red part. ive installed a free battery monitoring problem and the battery percentages are crazy! i think there is something wrong with iphone 3g OS 3.0
    Guru:
  • 1,894 Answers
This problem must not come in iphone. i bet you have a faulty product. contact service center immdediately.
Posted on Jul 27, 2009
How do I stop the battery from draining after only a few hours.
try letting the battery completely die and recharge it. Do this 2 or 3 times. Sometimes "topping up" a partially charged battery puts a memory into the battery and it wont allow you to do full charge.. I let my Nokia get to its last legs before replacing the battery with a spare and then fully charge the other one. Both batteries are now at least 6 years old.. Yes , its an old phone...
Apr 08, 2015 | Tracfone Wireless LG 440G
Camera retracts it's lens and turns itself off about 10 seconds after I turn it on
Have you fully charged the battery? if it is a new camera or battery,it needs at least 12 hrs of charge,to maintain good charge, if only a short time of charge was given from new the life of the battery will be greatly re-juiced,try a new battery with a full charge, if this fails your camera is probably faulty, take it back to get a replacement.
Sep 07, 2014 | Olympus FE-210 Digital Camera
Battery
Eventually your battery will have a short/no life indeed. Though this happens to all laptops.
Using your laptop while it is charging isn't going to damage anything. It just means that the battery will take longer to charge because you're using the laptop.
To get the most life out of the battery, fully charge it and then use it until it is empty. It's also a good idea to remove the battery when the laptop is connected to the mains supply.
All you're trying to do is extend the life of the battery. The day will come when it holds a short/no charge.
Jun 09, 2013 | Lenovo Computers & Internet
Battery life half of what it used to be
sometimes all a battery needs is a little exercise
try this
let it run down to 25% every morning when first turned on
then full recharge
then down to 50% every morning next week
then full recharge
like push ups for rechargeables
that's how get more life out of my batteries
this will take a while so don't expect a two day miracle
May 22, 2012 | ASUS Eee PC
I purchased lenovo z 570 laptop.clarification of regarding battery i am making 0 battery for every 15 days. (A) BATTERY is fully charged (100% ) , even though iam keeping plug in socket & using...
Not really, the older NiCad batteries get a memory effect if you keep charging from a half charged state, but modern Lithium batteries do not suffer from this problem.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.These rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 10, 2011 | Computers & Internet
I have a scootamart large scooter,not sure if 6 or 8 mph.batteries have been checked and are perfect but can only travel 5 or 6 miles on a full charge.what can be wrong.
Hi. How many amp/hours are your batteries?
Who tested your batteries, and how did they test them.
I have had batteries tested by an auto electrical technician, who said the batteries were OK. I knew at the time that the batteries were faulty.
What he did was do a short high current test, that he would normally do on a car battery.
To test batteries in a scooter you have to do a constant current test on fully charged batteries, and monitor the battery voltage. When the battery voltage drops to 10.5 volts across the 12 volt battery, that is considered a flat battery. Take the time elapsed for the test, and you can roughly work out the amp/hour rating of your batteries.
The amp/hour rating of a battery is worked out on a 10 or 20 discharge. A 40 amp/hour battery can supply 2 amps/ hour for 20 hours.
If you take 20 amps per hour, you will not get 2 hours of use. You will probably only get 1.5 to 1.75 hours of use. The more current ( amps ) you take out of a battery, the less amp/hours it will supply.
The best way to test your batteries is a constant current test, but they take a few hours, or try new batteries.
Also how long do you charge your batteries for. Most chargers need to be on at least over night to fully charge your batteries.
Some chargers have a green LED that comes on when the batteries are nearly full. This green LED is a guide only, and most batteries still need a few more hours to do a full charge.
Good luck. Neil.
Jun 10, 2010 | Health & Beauty
Short battery life
its not the charger its time for a new battery
Dec 17, 2009 | Sony Cyber-shot DSC-T700 Digital Camera
My Dell Inspiron 1520 seems to use a lot of battery power, even when the lid is closed, and nothing is running. Is there any way to save battery power, without going into standby mode, or turning off the...
How long does your battery usually last? If it lasts 2 hours or more, that's normal for a notebook computer. The standby mode and turning off of hard drives is what notebooks are designed to do to give you more battery life. If you have to have it on and available all the time without going into standy mode, you'll need to get used to charging it every couple of hours. If you want to get more battery life, try the following options:
1) have the display turned off when not in use (this setting can be changed where you set up your screensaver)
2) turn off the wireless function (if available) when not in use
3) have the computer go to standby mode after 10 or 15 minutes of inactivity.
4) lower the brightness of your display
All of the above assumes that you're getting a decent charge and can use the notebook unplugged for 2 hours or more. Naturally, over time, notebook batteries wear down and don't hold a charge as well as they once did. If your notebook is a few years old and you're only getting an hour or so on a full battery, then it is probably time to invest in a new battery. If your notebook is new and you are getting this short battery life, contact Dell for a replacement battery as yours may be defective.
One last thing about notebook batteries. They are designed to be charged up and run down. If you leave your computer plugged in to a/c power all the time while you are using your computer, this greatly speeds up the wearing down of the battery. Whenever possible, you should fully charge your battery and then run the battery down to 10% or less before plugging it back in. This ensures that you get the most battery life on a consistent basis.
Hope this help. Please take a moment to rate the solution. Thanks.
Mar 11, 2009 | Dell Computers & Internet
Charging
look i have the same problem it taks so mush time to charge
it and you can onliy play with it like in a 1:00 hour only what it worng
Jan 11, 2008 | Archos 605 WiFi Digital Media Player
Battery indicator/charging defect
Do you have a Treo desktop charger/sync cradle where you can drop the battery into the charger?
Jun 14, 2007 | Palm Treo 650 Handheld
Apple iPhone 3G Logo
114 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
