When the fax is sent it is completely black when received by the other person
    President:
  • 3,085 Answers
You have a bad SCANNER UNIT, uneconomical to repair.
Posted on Jul 27, 2009
Wont send message. Error no 442
This error indicates that the receiving machine (receiver) cannot receive the fax you just sent. The reasons might be unexpected shutdown of the machine (Receiver's machine) just before it completely received [or partially printed] the file you had sent or power failure during the process.
Another reason is, when we send color fax from Hp machine to another Machine (non-hp), this happens due to incompatibility issue.
Solutions are;
1. Restart both the machine after deleting the recently sent/received fax.
2. Send black and white only, not color.
3. Try again after the phone line seems not much busy which means when there's better transmission capability.
Good luck.
Thanks for using FixYa.
Jul 06, 2010 | HP OfficeJet 6110 All-In-One InkJet...
MFC 8300 Laser Printer: do i receive anything after i send a fax?...
Only if you have set the fax options to automatically print a sent item/transmission report. Otherwiase you will receive nothing unless the person or company you sent a fax to decides to fax you back.
May 06, 2010 | Brother MFC 8300 Laser Printer
New Drum and Toner and faxes sent are black
You have a bad SCANNER BLOCK. Expensive to repair.
May 05, 2010 | Brother IntelliFAX 4100 Laser Fax
Confirmation page shows zero pages sent. Is there a way to set to show the number of pages sent
I would first test a fax to see if it completes on your end then is received on it's entirety on the receiving end. Then print a fax transmittal report to confirm. Once that shows success, print your polling fax report and verify.
If it says zero pages sent, chances are the fax failed.
Jan 14, 2010 | Brother IntelliFAX 4100e All-In-One Laser...
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Fax problem
Something is blocking part of your scanner light, or scanner light may be bad. Check if the scanner light comes on, and check inside the original feeder and machine for a scrap of paper blocking the scanner light to the imaging drum.
Nov 26, 2008 | Brother IntelliFax-2820 Laser Fax
BLACK VERTICLE LINE IN FAXES SENT, NOT WHEN RECEIVED?
Lift to open the document cover and use a soft cloth to clean the glass were documents are scanned.Also clean the white plate on the upper side of the scanner.You identify the scanner by observing the direction documents faces while faxing.The scanner reads the document.
Nov 20, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
When sending the fax, the person is not receiving it, even though the transmission report says it was sent.
I think the receiving party has given you the wrong fax number. Your faxes are going to some other fax machine or their computer.
Sep 15, 2008 | Brother Office Equipment & Supplies
k24674
